Datasheet LT1783 (Analog Devices) - 3
Description1.25MHz, Over-The-Top Micropower, Rail-to-Rail Input and Output Op Amp in SOT-23
Pages / Page16 / 3 — ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply …
File Format / SizePDF / 183 Kb
ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the specifi ed
ELECTRICAL CHARACTERISTICS The denotes the specifi cations which apply over the specifi ed
LT1783
denotes the specifi cations which apply over the specifi ed temperature range, otherwise specifi cations are at TA = 25°C. VS = 3V, 0V; VS = 5V, 0V; VCM = VOUT = half supply, for the 6-lead part VPIN5 = 0V, pulse power tested unless otherwise specifi ed. (Note 4) LT1783C/LT1783I SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOS Input Offset Voltage TA = 25°C 400 800 μV 0°C ≤ TA ≤ 70°C l 950 μV –40°C ≤ TA ≤ 85°C l 1100 μV Input Offset Voltage Drift (Note 9) l 2 5 μV/°C IOS Input Offset Current l 4 8 nA VCM = 18V (Note 5) l 7 μA IB Input Bias Current l 45 80 nA VCM = 18V (Note 5) l 35 60 μA SHDN or VS = 0V, VCM = 0V to 18V 0.1 nA Input Bias Current Drift l 0.06 nA/°C Input Noise Voltage 0.1Hz to 10Hz 0.6 μVP-P en Input Noise Voltage Density f = 1kHz 20 nV/√Hz in Input Noise Current Density f = 1kHz 0.14 pA/√Hz RIN Input Resistance Differential l 0.65 1.3 MΩ Common Mode, VCM = 0V to (VCC – 1V) 1 GΩ Common Mode, VCM = 0V to 18V l 0.3 0.5 MΩ CIN Input Capacitance 5 pF Input Voltage Range l 0 18 V CMRR Common Mode Rejection Ratio VCM = 0V to VCC – 1V l 90 100 dB (Note 5) VCM = 0V to 18V (Note 8) l 68 80 dB PSRR Power Supply Rejection Ratio VS = 3V to 12.5V, VCM = VO = 1V l 90 100 dB AVOL Large-Signal Voltage Gain VS = 3V, VO = 500mV to 2.5V, RL = 10k 200 1500 V/mV VS = 3V, 0°C ≤ TA ≤ 70°C l 133 V/mV VS = 3V, –40°C ≤ TA ≤ 85°C l 100 V/mV VS = 5V, VO = 500mV to 4.5V, RL = 10k 400 1500 V/mV VS = 5V, 0°C ≤ TA ≤ 70°C l 250 V/mV VS = 5V, –40°C ≤ TA ≤ 85°C l 200 V/mV VOL Output Voltage Swing LOW No Load l 3 8 mV ISINK = 5mA l 200 400 mV VS = 5V, ISINK = 10mA l 330 600 mV VOH Output Voltage Swing HIGH VS = 3V, No Load l 2.91 2.94 V VS = 3V, ISOURCE = 5mA l 2.6 2.8 V VS = 5V, No Load l 4.91 4.94 V VS = 5V, ISOURCE = 10mA l 4.5 4.74 V ISC Short-Circuit Current (Note 2) VS = 3V, Short to GND 5 10 mA VS = 3V, Short to VCC 15 30 mA VS = 5V, Short to GND 15 30 mA VS = 5V, Short to VCC 20 40 mA Minimum Supply Voltage l 2.5 2.7 V Reverse Supply Voltage IS = –100μA l 18 V IS Supply Current 210 300 μA (Note 6) 0°C ≤ TA ≤ 70°C l 350 μA –40°C ≤ TA ≤ 85°C l 375 μA Supply Current, SHDN VPIN5 = 2V, No Load (Note 10) l 5 18 μA ISHDN Shutdown Pin Current VPIN5 = 0.3V, No Load (Note 10) l 0.5 nA VPIN5 = 2V, No Load (Note 10) l 2 8 μA VPIN5 = 5V, No Load (Note 10) 5 μA Shutdown Output Leakage Current VPIN5 = 2V, No Load (Note 10) l 0.05 1 μA Maximum Shutdown Pin Current VPIN5 = 18V, No Load (Note 10) l 10 30 μA 1783fd 3
