Datasheet LT1782 (Analog Devices) - 6
DescriptionMicropower, Over-The-Top SOT-23, Rail-to-Rail Input and Output Op Amp
Pages / Page16 / 6 — ELECTRICAL CHARACTERISTICS. The. denotes the specifications which apply …
File Format / SizePDF / 527 Kb
LT1782
denotes the specifications which apply over the full operating temperature range of –40°C ≤ TA ≤ 125°C. VS = 3V, 0V; VS = 5V, 0V; VCM = VOUT = half supply, for the 6-lead part VPIN5 = 0V, pulse power tested unless otherwise specified. (Note 4) LT1782H SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
AVOL Large-Signal Voltage Gain VS = 3V, VO = 500mV to 2.5V, RL = 10k 200 1500 V/mV l 50 V/mV VS = 5V, VO = 500mV to 4.5V, RL = 10k 400 1500 V/mV l 80 V/mV VOL Output Voltage Swing LOW No Load l 15 mV ISINK = 5mA l 900 mV VS = 5V, ISINK = 10mA l 1500 mV VOH Output Voltage Swing HIGH VS = 3V, No Load l 2.85 V VS = 3V, ISOURCE = 5mA l 2.20 V VS = 5V, No Load l 4.85 V VS = 5V, ISOURCE = 10mA l 3.80 V PSRR Power Supply Rejection Ratio VS = 3V to 12.5V, VCM = VO = 1V l 80 dB Minimum Supply Voltage l 2.7 V Reverse Supply Voltage IS = –100µA l 18 V IS Supply Current 40 55 µA l 100 µA Supply Current, SHDN VPIN5 = 2V, No Load (Note 10) l 25 µA ISHDN Shutdown Pin Current VPIN5 = 0.3V, No Load (Note 10) l 0.5 nA VPIN5 = 2V, No Load (Note 10) l 12 µA Output Leakage Current VPIN5 = 2V, No Load (Note 10) l 3 µA Maximum Shutdown Pin Current VPIN5 = 18V, No Load l 45 µA VL Shutdown Pin Input Low Voltage (Note 10) l 0.3 V VH Shutdown Pin Input High Voltage (Note 10) l 2 V GBW Gain Bandwidth Product f = 10kHz (Note 5) 110 200 kHz l 65 kHz SR Slew Rate AV = –1, RL = ∞ (Note 7) 0.035 0.07 V/µs l 0.020 V/µs
The
denotes the specifications which apply over the full operating temperature range of –40°C ≤ TA ≤ 125°C. VS = ±5V, VCM = 0V, VOUT = 0V, for the 6-lead part VPIN5 = V–, pulse power tested unless otherwise specified. (Note 4) LT1782H SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOS Input Offset Voltage 500 900 µV l 3.2 mV ∆VOS/∆T Input Offset Voltage Drift (Note 9) l 15 µV/°C IOS Input Offset Current l 3 nA IB Input Bias Current l 30 nA CMRR Common Mode Rejection Ratio VCM = –4.7V to 13V l 60 dB AVOL Large-Signal Voltage Gain VS = ±4V, RL = 10k 55 150 V/mV l 20 V/mV VO Output Voltage Swing No Load l ±4.85 V ISINK = ±5mA l ±4.10 V ISINK = ±10mA l ±3.50 V 1782fc 6 Document Outline Features Description Applications Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Applications Information Simplified Schematic Typical Applications Package Description Revision History Typical Application Related Parts
