Datasheet LT1637 (Analog Devices) - 2
Description1.1MHz, 0.4V/µs Over-The-Top Micropower, Rail-To-Rail Input and Output Op Amp
Pages / Page16 / 2 — ABSOLUTE AXI U. RATI GS (Note 1). PACKAGE/ORDER I FOR ATIO. 3V A D 5V …
File Format / SizePDF / 366 Kb
ABSOLUTE AXI U. RATI GS (Note 1). PACKAGE/ORDER I FOR ATIO. 3V A D 5V ELECTRICAL CHARACTERISTICS. The
ABSOLUTE AXI U RATI GS (Note 1) PACKAGE/ORDER I FOR ATIO 3V A D 5V ELECTRICAL CHARACTERISTICS The
LT1637
W W W U ABSOLUTE AXI U RATI GS (Note 1)
Total Supply Voltage (V + to V –) .. 44V Specified Temperature Range (Note 4) Input Differential Voltage ... 44V LT1637C/LT1637I .. – 40°C to 85°C Input Current .. ±25mA LT1637H .. – 40°C to 125°C Shutdown Pin Voltage Above V – ... 32V LT1637MP ... –55°C to 125°C Shutdown Pin Current .. ±10mA Junction Temperature ... 150°C Output Short-Circuit Duration (Note 2) ... Continuous Junction Temperature (DD Package) ... 125°C Operating Temperature Range (Note 3) Storage Temperature Range ... – 65°C to 150°C LT1637C/LT1637I .. – 40°C to 85°C Storage Temperature Range LT1637H .. – 40°C to 125°C (DD Package) ... – 65°C to 125°C LT1637MP ... –55°C to 125°C Lead Temperature (Soldering, 10 sec).. 300°C
U W U PACKAGE/ORDER I FOR ATIO
TOP VIEW TOP VIEW TOP VIEW NULL 1 8 NULL NULL 1 8 NULL NULL 1 8 NULL –IN A 2 7 V+ –IN 2 7 V+ –IN 2 7 V+ +IN A 3 6 OUT +IN 3 6 OUT +IN 3 6 OUT V– 4 5 SHDN V– 4 5 SHDN V– 4 5 SHDN MS8 PACKAGE 8-LEAD PLASTIC MSOP N8 PACKAGE S8 PACKAGE DD PACKAGE TJMAX = 150°C, θJA = 250°C/W 8-LEAD PDIP 8-LEAD PLASTIC SO 8-LEAD (3mm × 3mm) PLASTIC DFN TJMAX = 150°C, θJA = 150°C/W (N8) TJMAX = 125°C, θJA = 160°C/W (NOTE 2) TJMAX = 150°C, θJA = 190°C/W (S8) UNDERSIDE METAL CONNECTED TO V– ORDER PART DD PART* ORDER PART MS8 PART* ORDER PART S8 PART NUMBER MARKING NUMBER MARKING NUMBER MARKING LT1637CDD LAAK LT1637CMS8 LTIE LT1637CN8 1637 LT1637IDD LAAK LT1637IMS8 LTIE LT1637CS8 1637I LT1637IN8 1637H LT1637IS8 1637MP LT1637HS8 LT1637MPS8 *The temperature grades are identified by a label on the shipping container. Consult factory for parts specified with wider operating temperature ranges.
U 3V A D 5V ELECTRICAL CHARACTERISTICS The
denotes the specifications which apply over the full operating temperature range of –40
C
TA
85
C, otherwise specifications are at TA = 25
C. VS = 3V, 0V; VS = 5V, 0V; VSHDN = V–,VCM = VOUT = half supply unless otherwise specified. (Note 4) LT1637C/LT1637I SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOS Input Offset Voltage N8, S8 Packages 100 350 µV 0°C ≤ TA ≤ 70°C ● 550 µV – 40°C ≤ TA ≤ 85°C ● 700 µV MS8 Package 100 350 µV 0°C ≤ TA ≤ 70°C ● 750 µV – 40°C ≤ TA ≤ 85°C ● 1100 µV DD Package 125 550 µV 0°C ≤ TA ≤ 70°C ● 950 µV – 40°C ≤ TA ≤ 85°C ● 1100 µV 1637fd 2
