Datasheet LT1637 (Analog Devices) - 6
Description1.1MHz, 0.4V/µs Over-The-Top Micropower, Rail-To-Rail Input and Output Op Amp
Pages / Page16 / 6 — 3V A D 5V ELECTRICAL CHARACTERISTICS. The
File Format / SizePDF / 366 Kb
3V A D 5V ELECTRICAL CHARACTERISTICS The
LT1637
U 3V A D 5V ELECTRICAL CHARACTERISTICS The
denotes the specifications which apply over the full operating temperature range of –40
C
TA
125
C for LT1637H and –55
C
TA
125
C for LT1637MP. VS = 3V, 0V; VS = 5V, 0V; VCM = VOUT = half supply unless otherwise specified. (Note 4) LT1637H/LT1637MP SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOS Input Offset Voltage 100 450 µV ● 3 mV Input Offset Voltage Drift (Note 9) ● 3 10 µV/°C IOS Input Offset Current ● 15 nA VCM = 44V (Note 5) ● 10 µA IB Input Bias Current ● 150 nA VCM = 44V (Note 5) ● 100 µA Input Voltage Range ● 0.3 44 V CMRR Common Mode Rejection Ratio VCM = 0.3V to (VCC – 1V) ● 72 dB (Note 5) VCM = 0.3V to 44V ● 74 dB AVOL Large-Signal Voltage Gain VS = 3V, VO = 500mV to 2.5V, RL = 10k 150 400 V/mV ● 20 V/mV VS = 5V, VO = 500mV to 4.5V, RL = 10k 300 800 V/mV ● 35 V/mV VOL Output Voltage Swing LOW No Load ● 15 mV ISINK = 5mA ● 900 mV VS = 5V, ISINK = 10mA ● 1500 mV VOH Output Voltage Swing HIGH VS = 3V, No Load ● 2.90 V VS = 3V, ISOURCE = 5mA ● 2.05 V VS = 5V, No Load ● 4.90 V VS = 5V, ISOURCE = 10mA ● 3.50 V PSRR Power Supply Rejection Ratio VS = 3V to 12.5V, VCM = VO = 1V ● 80 dB Minimum Supply Voltage ● 2.7 V Reverse Supply Voltage IS = – 100µA ● 23 V IS Supply Current (Note 6) 190 250 µA ● 400 µA Supply Current, SHDN VPIN5 = 2V, No Load (Note 6) ● 15 µA ISHDN Shutdown Pin Current VPIN5 = 0.3V, No Load (Note 6) ● 200 nA VPIN5 = 2V, No Load (Note 5) ● 7 µA Output Leakage Current, SHDN VPIN5 = 2V, No Load (Note 6) ● 5 µA Maximum Shutdown Pin Current VPIN5 = 32V, No Load (Note 5) ● 200 µA GBW Gain-Bandwidth Product f = 10kHz (Note 5) 650 1000 kHz ● 350 kHz SR Slew Rate AV = – 1, RL = ∞ (Note 7) 0.210 0.35 V/µs ● 0.1 V/µs 1637fd 6
