Datasheet LT1351 (Analog Devices) - 8
Description | 250µA, 3MHz, 200V/µs Operational Amplifier |
Pages / Page | 16 / 8 — TYPICAL PERFORMANCE CHARACTERISTICS. Slew Rate vs Supply Voltage. Slew … |
File Format / Size | PDF / 312 Kb |
TYPICAL PERFORMANCE CHARACTERISTICS. Slew Rate vs Supply Voltage. Slew Rate vs Temperature. Slew Rate vs Input Level
LT1351
W U TYPICAL PERFORMANCE CHARACTERISTICS Slew Rate vs Supply Voltage Slew Rate vs Temperature Slew Rate vs Input Level
200 250 200 TA = 25°C AV = –1 TA = 25°C AV = –1 RF = RG = RL = 5k 175 VS = ±15V RF = RG = 5k SR = (SR+ + SR–)/2 200 AV = –1 150 SR = (SR+ + SR–)/2 150 RFB = RG = 5k VS = ±15V SR = (SR+ + SR–)/2 µs) µs) µs) 125 150 100 100 100 75 SLEW RATE (V/ SLEW RATE (V/ SLEW RATE (V/ 50 VS = ±5V 50 50 25 0 0 0 0 5 10 15 –50 –25 0 25 50 75 100 125 0 4 8 12 16 20 24 SUPPLY VOLTAGE (±V) TEMPERATURE (°C) INPUT LEVEL (VP-P) 1351 G22 1351 G23 1351 G24
Total Harmonic Distortion Undistorted Output Swing Undistorted Output Swing vs Frequency vs Frequency (
15V) vs Frequency (
5V)
1 30 10 TA = 25°C A V V = –1 9 S = ±15V RL = 5k 25 8 V ) O = 2VP-P AV = 1 P-P P-P 7 0.1 20 AV = 1 6 AV = –1 15 5 4 0.01 10 3 AV = –1 OUTPUT VOLTAGE (V OUTPUT VOLTAGE (V 2 5 VS = ±15V VS = ±5V TOTAL HARMONIC DISTORTION (%) RL = 5k 1 RL = 5k AV = 1 THD = 1% THD = 1% 0.001 0 0 10 100 1k 10k 100k 10k 100k 1M 10k 100k 1M FREQUENCY (Hz) FREQUENCY (Hz) FREQUENCY (Hz) 1351 G26 1351 G27 1351 G25
2nd and 3rd Harmonic Distortion Shutdown Supply Current vs Frequency vs Temperature Capacitive Load Handling
– 30 100 100 VS = ±15V VS = ±15V TA = 25°C A 90 90 V = 1 VS = ±15V – 40 RL = 5k 80 80 RL = 5k VO = 2VP-P µA) 70 70 – 50 VSHDN = VEE + 0.2 AV = 1 3RD HARMONIC 60 60 – 60 50 V 50 SHDN = VEE + 0.1 40 40 –70 OVERSHOOT (%) AV = –1 30 30 SUPPLY CURRENT ( HARMONIC DISTORTION (dB) 2ND HARMONIC 20 V 20 – 80 SHDN = VEE 10 10 – 90 0 0 100k 1M –50 –25 0 25 50 75 100 125 10p 100p 1n 10n 0.1µ 1µ FREQUENCY (Hz) TEMPERATURE (°C) CAPACITIVE LOAD (F) 1351 G28 1351 G29 1351 G30 8
