Datasheet LT1077 (Analog Devices) - 5
DescriptionMicropower, Single Supply, Precision Op Amp
Pages / Page16 / 5 — ELECTRICAL CHARACTERISTICS The. denotes the specifications which apply …
File Format / SizePDF / 309 Kb
ELECTRICAL CHARACTERISTICS The. denotes the specifications which apply over the temperature range of –55. 125
ELECTRICAL CHARACTERISTICS The denotes the specifications which apply over the temperature range of –55 125
LT1077
C
TA
125
C for AM/M grades, – 40
C
TA
85
C for AI/I grades. VS =
15V unless otherwise noted. LT1077AM/AI LT1077M/I SYMBOL PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
VOS Input Offset Voltage ● 60 330 75 450 µV ∆VOS/∆T Input Offset Voltage Drift LT1077IS8 (Note 6) ● 1.1 3 µV/°C IOS Input Offset Current ● 0.08 0.60 0.08 0.80 nA IB Input Bias Current ● 8 11 8 13 nA AVOL Large-Signal Voltage Gain VO = ±10V, RL = 5k ● 300 1000 250 1000 V/mV CMRR Common Mode Rejection Ratio VCM = 13V, –14.9V ● 94 107 90 106 dB PSRR Power Supply Rejection Ratio VS = 5V, 0V to ±18V ● 100 118 97 116 dB Maximum Output Voltage Swing RL = 5k ● ±11 ±13.5 ±11 ±13.5 V IS Supply Current ● 60 95 60 105 µA
The
denotes the specifications which apply over the temperature range of 0
C
TA
70
C. VS =
15V unless otherwise noted. LT1077AC LT1077C/S8 SYMBOL PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
VOS Input Offset Voltage ● 40 230 50 320 µV LT1077S8 ● 65 450 µV ∆VOS/∆T Input Offset Voltage Drift (Note 6) ● 0.4 1.8 0.5 2.5 µV/°C LT1077S8 (Note 6) ● 0.8 3.5 µV/°C IOS Input Offset Current ● 0.07 0.45 0.07 0.60 nA IB Input Bias Current ● 7 10 7 12 nA AVOL Large-Signal Voltage Gain VO = ±10V, RL = 5k ● 500 2000 400 2000 V/mV CMRR Common Mode Rejection Ratio VCM = 13V, –15V ● 97 108 94 107 dB PSRR Power Supply Rejection Ratio VS = 5V, 0V to ±18V ● 103 120 100 118 dB Maximum Output Voltage Swing RL = 5k ● ±11 ±13.6 ±11 ±13.6 V IS Supply Current ● 59 85 59 95 µA
Note 1:
Absolute Maximum Ratings are those values beyond which the life
Note 4:
This parameter is guaranteed by design and is not tested. of a device may be impared.
Note 5:
Power supply rejection ratio is measured at the minimum supply
Note 2:
Slew rate at 5V, 0V is guaranteed by inference from the slew rate voltage. The op amps actually work at 1.8V supply but with a typical offset measurement at ±15V. skew of – 300µV.
Note 3:
This parameter is tested on a sample basis only. All noise
Note 6:
This parameter is not 100% tested. parameters are tested with VS = ± 2.5V, VO = 0V. 1077fa 5
