Datasheet LT1078, LT1079 (Analog Devices) - 2
DescriptionMicropower, Dual and Quad, Single Supply, Precision Op Amps
Pages / Page20 / 2 — ABSOLUTE MAXIMUM RATINGS (Note 1). (OBSOLETE) ... PACKAGE/ORDER …
File Format / SizePDF / 618 Kb
ABSOLUTE MAXIMUM RATINGS (Note 1). (OBSOLETE) ... PACKAGE/ORDER INFORMATION. OBSOLETE PACKAGES. OBSOLETE PACKAGE
ABSOLUTE MAXIMUM RATINGS (Note 1) (OBSOLETE) .. PACKAGE/ORDER INFORMATION OBSOLETE PACKAGES OBSOLETE PACKAGE
LT1078/LT1079
W W W U ABSOLUTE MAXIMUM RATINGS (Note 1)
Supply Voltage .. ±22V Operating Temperature Range Differential Input Voltage ... ±30V LT1078AM/LT1078M/ Input Voltage ... Equal to Positive Supply Voltage LT1079AM/LT1079M
(OBSOLETE) ...
– 55°C to 125°C .. 5V Below Negative Supply Voltage LT1078I/LT1079I .. – 40°C to 85°C Output Short-Circuit Duration .. Indefinite LT1078AC/LT1078C/LT1078S8/ Storage Temperature Range LT1079AC/LT1079C .. 0°C to 70°C All Grades ... – 65°C to 150°C Lead Temperature (Soldering, 10 sec).. 300°C
U W U PACKAGE/ORDER INFORMATION
TOP VIEW TOP VIEW TOP VIEW V+ +IN A 1 8 –IN A OUT A 1 8 V+ 8 A V– 2 7 OUT A OUT A 1 7 OUT B –IN A 2 7 OUT B A A B +IN B 3 6 V+ –IN A 2 6 –IN B +IN A 3 6 –IN B B B –IN B 4 5 OUT B V– 4 5 +IN B +IN A 3 5 +IN B S8 PACKAGE 4 N8 PACKAGE 8-LEAD PLASTIC SO V– (CASE) 8-LEAD PDIP NOTE: THIS PIN CONFIGURATION DIFFERS FROM THE H PACKAGE TJMAX = 100°C, θJA = 130°C/ W (N8) 8-LEAD DIP PIN LOCATIONS. INSTEAD, IT FOLLOWS 8-LEAD TO-5 METAL CAN THE INDUSTRY STANDARD LT1013DS8 SO PACKAGE ORDER PART NUMBER CONFIGURATION. FOR SIMILAR PERFORMANCE WITH T TRADITIONAL DIP PINOUT, SEE THE LT2078 JMAX = 150°C, θJA = 150°C/ W, θJC = 45°C/ W LT1078ACN8 TJMAX = 110°C, θJA = 220°C/ W ORDER PART NUMBER LT1078CN8 ORDER PART NUMBER LT1078IN8 LT1078ACH LT1078IS8 LT1078MH LT1078S8 J8 PACKAGE 8-LEAD PDIP TJMAX = 150°C, θJA = 100°C/ W (J8) PART MARKING
OBSOLETE PACKAGES
LT1078AMJ8 1078 Consider the N8 and S8 Packages for Alternate Source LT1078MJ8 TOP VIEW ORDER PART TOP VIEW ORDER PART OUT A 1 14 OUT D NUMBER OUT A 1 16 OUT D NUMBER –IN A 2 13 –IN D –IN A 2 15 –IN D A D A D LT1079ISW +IN A 3 12 +IN D LT1079ACN +IN A 3 14 +IN D V+ 4 11 V– LT1079CN V+ 4 13 V– LT1079SW +IN B 5 10 +IN C LT1079IN +IN B 5 12 +IN C B C B C –IN B 6 9 –IN C –IN B 6 11 –IN C OUT B 7 8 OUT C OUT B 7 10 OUT C NC 8 9 NC N PACKAGE 14-LEAD PDIP SW PACKAGE TJMAX = 110°C, θJA = 130°C/ W (N) 16-LEAD PLASTIC SO WIDE J PACKAGE NOTE: FOR 14-PIN NARROW LT1079MJ 14-LEAD CERAMIC DIP PACKAGE SEE THE LT2079 TJMAX = 150°C, θJA = 100°C/ W (J) TJMAX = 110°C, θJA = 150°C/ W
OBSOLETE PACKAGE
Consider the N Packages for Alternate Source 10789fe 2
