Datasheet LT1178, LT1179 (Analog Devices) - 4
Description17µA Max, Dual and Quad, Single Supply, Precision Op Amps
Pages / Page12 / 4 — ELECTRICAL CHARACTERISTICS The. denotes specifications which apply over …
File Format / SizePDF / 247 Kb
ELECTRICAL CHARACTERISTICS The. denotes specifications which apply over the full operating. temperature range of –40
ELECTRICAL CHARACTERISTICS The denotes specifications which apply over the full operating temperature range of –40
LT1178/LT1179
C
TA
85
C for I grades, 0
C
TA
70
C for SW grades, VS = 5V, 0V; VCM = 0.1V, VO = 1.4V, unless noted. (Note 7) LT1178I/LT1179I LT1178SW/LT1179SW SYMBOL PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
VOS lnput Offset Voltage LT1178 ● 80 315 120 650 µV LT1179 ● 80 345 130 800 µV ∆VOS/∆T Input Offset Voltage Drift (Note 6) ● 0.6 3.0 0.8 4.5 µV/°C IOS Input Offset Current ● 0.07 0.7 0.06 0.50 nA IB Input Bias Current ● 4 8 3 7 nA CMRR Common Mode Rejection VCM = 0.05V to 3.2V I grade ● 84 98 86 100 dB Ratio VCM = 0V to 3.4V S grade PSRR Power Supply Rejection VS = 3.0V to 12V I grade ● 86 100 88 102 dB Ratio VS = 2.5V to 12V S grade AVOL Large-Signal Voltage Gain VO = 0.05V to 4V, No Load (Note 4) ● 55 350 80 500 V/mV VO = 0.05V to 3.5V, RL = 50k ● 35 130 45 160 V/mV Maximum Output Voltage Output Low, No Load ● 9 13 8 11 mV Swing Output Low, ISINK = 100µA ● 160 220 140 190 mV Output High, No Load ● 3.9 4.2 4.1 4.3 V Output High, 2k to GND ● 3.0 3.7 3.3 3.8 V IS Supply Current per Amplifier ● 15 27 15 24 µA
The
denotes specifications which apply over the full operating temperature range of 0
C
TA
70
C, VS = 5V, 0V, VCM = 0.1V, VO = 1.4V, unless noted. LT1178AC/LT1179AC LT1178C/S8/LT1179C SYMBOL PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
VOS lnput Offset Voltage LT1178 ● 50 170 65 250 µV LT1178S8 ● 85 350 µV LT1179 ● 60 200 70 290 µV ∆VOS/∆T Input Offset Voltage Drift (Note 6) ● 0.5 2.2 0.6 3.0 µV/°C LT1178S8 ● 0.6 3.5 µV/°C IOS Input Offset Current ● 0.06 0.35 0.06 0.50 nA IB Input Bias Current ● 3 6 3 7 nA CMRR Common Mode Rejection Ratio VCM = 0V to 3.4V ● 90 101 86 100 dB PSRR Power Supply Rejection Ratio VS = 2.5V to 12V ● 90 102 88 102 dB AVOL Large-Signal Voltage Gain VO = 0.05V to 4V, No Load (Note 4) ● 105 500 80 500 V/mV VO = 0.05V to 3.5V, RL = 50k ● 55 160 45 160 V/mV Maximum Output Voltage Output Low, No Load ● 8 11 8 11 mV Swing Output Low, ISINK = 100µA ● 140 190 140 190 mV Output High, No Load ● 4.1 4.3 4.1 4.3 V Output High, 2k to GND ● 3.3 3.8 3.3 3.8 V IS Supply Current per Amplifier ● 14 21 15 24 µA 11789fb 4
