Datasheet LTC2066, LTC2067 (Analog Devices) - 2
Description | 10μA Supply Current, Low IB, Zero-Drift Operational Amplifier |
Pages / Page | 28 / 2 — ABSOLUTE MAXIMUM RATINGS (Note 1). PIN CONFIGURATION. ORDER INFORMATION … |
Revision | A |
File Format / Size | PDF / 4.6 Mb |
ABSOLUTE MAXIMUM RATINGS (Note 1). PIN CONFIGURATION. ORDER INFORMATION TAPE AND REEL (MINI). TAPE AND REEL. PART MARKING*
LTC2066/LTC2067
Total Supply Voltage (V+ to V–) ..5.5V Output Short-Circuit Duration Differential Input Current (+IN to –IN) (Note 2) .. ±10mA (Note 3) ..Thermally Limited Differential Input Voltage (+IN to –IN) ..5.5V Operating and Specified Temperature Range (Note 4) Input Voltage LTC2066I/LTC2067I ...–40°C to 85°C +IN, –IN, SHDN ...(V–) – 0.3V to (V+) + 0.3V LTC2066H/LTC2067H .. –40°C to 125°C Input Current Maximum Junction Temperature .. 150°C +IN, –IN, SHDN (Note 2) .. ±10mA Storage Temperature Range .. –65°C to 150°C
PIN CONFIGURATION
LTC2066 LTC2066 TOP VIEW TOP VIEW +IN 1 6 V+ OUT 1 5 V+ V– 2 + 5 SHDN V– 2 – + – –IN 3 4 OUT +IN 3 4 –IN SC6 PACKAGE S5 PACKAGE 6-LEAD PLASTIC SC70 5-LEAD PLASTIC TSOT-23 θJA = 265°C/W (Note 5) θJA = 215°C/W (Note 5) LTC2067 LTC2067 TOP VIEW TOP VIEW OUTA 1 10 V+ OUTA 1 8 V+ –INA 2 9 OUTB A –INA 2 7 OUTB A +INA 3 11 8 –INB +INA 3 6 –INB B V– 4 7 +INB V– 4 B 5 +INB NC 5 6 SHDN MS8 PACKAGE 8-LEAD PLASTIC MSOP DD PACKAGE θJA = 163°C/W, θJC = 40°C/W (Note 5) 10-LEAD (3mm × 3mm) PLASTIC DFN θJA = 43°C/W, θJC = 5.5°C/W (Note 5) EXPOSED PAD (PIN 11) IS CONNECTED TO V– (PIN 4) (PCB CONNECTION OPTIONAL)
ORDER INFORMATION TAPE AND REEL (MINI) TAPE AND REEL PART MARKING* PACKAGE DESCRIPTION TEMPERATURE RANGE
LTC2066ISC6#TRMPBF LTC2066ISC6#TRPBF LHDB 6-Lead Plastic SC70 –40°C to 85°C LTC2066HSC6#TRMPBF LTC2066HSC6#TRPBF LHDB 6-Lead Plastic SC70 –40°C to 125°C LTC2066IS5#TRMPBF LTC2066IS5#TRPBF LTHCZ 5-Lead Plastic TSOT-23 –40°C to 85°C LTC2066HS5#TRMPBF LTC2066HS5#TRPBF LTHCZ 5-Lead Plastic TSOT-23 –40°C to 125°C LTC2067IMS8#TRMPBF LTC2067IMS8#TRPBF LTHDC 8-Lead Plastic MSOP –40°C to 85°C LTC2067HMS8#TRMPBF LTC2067HMS8#TRPBF LTHDC 8-Lead Plastic MSOP –40°C to 125°C LTC2067IDD#TRMPBF LTC2067IDD#TRPBF LHDD 10-Lead (3mm × 3mm) Plastic DFN –40°C to 85°C LTC2067HDD#TRMPBF LTC2067HDD#TRPBF LHDD 10-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C Contact the factory for parts specified with wider operating temperature ranges. *The temperature grade is identified by a label on the shipping container. Parts ending with PBF are RoHS and WEEE compliant. Tape and reel specifications. Some packages are available in 500 unit reels through designated sales channels with #TRMPBF suffix. Rev A 2 For more information www.analog.com Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Typical Application Related Parts
