Datasheet LTC6255, LTC6256, LTC6257 (Analog Devices) - 6
Description6.5MHz, 65µA Power Efficient Rail-to-Rail I/O Op Amps
Pages / Page26 / 6 — 1.8V ELECTRICAL CHARACTERISTICS. The. denotes the specifications which …
RevisionE
File Format / SizePDF / 815 Kb
1.8V ELECTRICAL CHARACTERISTICS. The. denotes the specifications which apply over the full
1.8V ELECTRICAL CHARACTERISTICS The denotes the specifications which apply over the full
LTC6255/LTC6256/LTC6257
l
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. VSUPPLY = 1.8V, VCM = VOUT = 0.4V, CL = 10pF, VSHDN is unconnected. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOH Output Swing High (Input Overdrive 30mV), No Load 24 55 mV Measured from V+ l 60 mV ISOURCE = 100µA 30 65 mV l 75 mV ISOURCE = 1mA 75 135 mV l 150 mV ISC Output Short-Circuit Current 12 17 mA l 3 mA IS Supply Current per Amplifier 53 60 68 µA l 35 83 µA Supply Current in Shutdown 1.4 2.0 µA l 3.0 µA ISHDN Shutdown Pin Current VSHDN = 0.5V l –480 –350 nA VSHDN = 1.3V l –160 –40 nA VIL SHDN Input Low Voltage Disable l 0.5 V VIH SHDN Input High Voltage Enable l 1.3 V tON Turn-On Time SHDN Toggle From 0V to 1.8V 150 µs tOFF Turn-Off Time SHDN Toggle From 1.8V to 0V 50 µs BW –3dB Closed Loop Bandwidth AV = 1 4 MHz GBW Gain-Bandwidth Product f = 200kHz 2.4 6 MHz l 1.8 MHz TS Settling Time, 0.3V to 1.5V, Unity Gain 0.1% 4 µs 0.01% 6 µs SR Slew Rate AV = –1, VOUT = 0.3V to 1.5V, CLOAD = 10pF 0.9 1.5 V/µs l 0.75 V/µs FPBW Full Power Bandwidth (Note 8) 1.2VP-P 400 kHz THD+N Total Harmonic Distortion and Noise f = 500Hz, AV = 2, RL = 4kΩ, VOUTP-P = 1V 0.006 % VIN = 0.25V to 0.75V 84 dB
Note 1:
Note 5:
The LTC6255C/LTC6256C/LTC6257C are guaranteed to meet may cause permanent damage to the device. Exposure to any Absolute the specified performance from 0°C to 70°C. The LTC6255C/LTC6256C/ Maximum Rating condition for extended periods may affect device LTC6257C are designed, characterized and expected to meet specified reliability and lifetime. performance from –40°C to 85°C but are not tested or QA sampled at
Note 2:
The inputs are protected by back-to-back diodes as well as ESD these temperatures. The LTC6255I/LTC6256I/LTC6257I are guaranteed protection diodes to each power supply. If the differential input voltage to meet specified performance from –40°C to 85°C. The LTC6255H/ exceeds 3.6V or the input extends more than 500mV beyond the power LTC6256H/LTC6257H are guaranteed to meet specified performance supply, the input current should be limited to less than 10mA. from –40°C to 125°C.
Note 3:
A heat sink may be required to keep the junction temperature
Note 6:
Thermal resistance varies with the amount of PC board metal below the absolute maximum rating when the output is shorted connected to the package. The specified values are for short traces indefinitely. connected to the leads.
Note 4:
The LTC6255C/LTC6256C/LTC6257C and LTC6255I/LTC6256I/
Note 7:
The input bias current is the average of the currents through the LTC6257I are guaranteed functional over the temperature range of –40°C positive and negative input pins. to 85°C. The LTC6255H/LTC6256H/LTC6257H are guaranteed functional
Note 8:
Full power bandwidth is calculated from the slew rate FPBW = over the temperature range of –40°C to 125°C. SR/π • VP-P. Rev E 6 For more information www.analog.com Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information 5V Electrical Characteristics 1.8V Electrical Characteristics Typical Performance Characteristics Pin Functions Simplified Schematic Operation Applications Information Typical Applications Package Description Typical Application Related Parts
