Datasheet LTC3624, LTC3624-2 (Analog Devices) - 2
Description | 17V, 2A Synchronous Step-Down Regulator with 3.5μA Quiescent Current |
Pages / Page | 20 / 2 — absoluTe MaxiMuM raTings (Note 1). pin conFiguraTion. orDer inForMaTion … |
File Format / Size | PDF / 327 Kb |
absoluTe MaxiMuM raTings (Note 1). pin conFiguraTion. orDer inForMaTion http://www.linear.com/product/LTC3624#orderinfo
LTC3624/LTC3624-2
VIN Voltage ... –0.3V to 17V Operating Junction Temperature Range RUN Voltage... –0.3V to 17V (Notes 2, 5) .. –40°C to 150°C MODE/SYNC, FB Voltages .. –0.3V to 6V Storage Temperature Range .. –65°C to 150°C INTVCC, PGOOD Voltages .. –0.3V to 6V
pin conFiguraTion
TOP VIEW TOP VIEW SW 1 12 GND SW 1 8 GND SW 2 11 GND V V 3 13 10 MODE/SYNC IN 2 7 9 MODE/SYNC IN GND GND V 4 9 INTV RUN 3 6 INTV IN CC CC RUN 5 8 FB PGOOD 4 5 FB PGOOD 6 7 NC MSE PACKAGE DD PACKAGE 12-LEAD PLASTIC MSOP 8-LEAD (3mm × 3mm) PLASTIC DFN TJMAX = 150°C, θJA = 40°C/W, θJC = 10°C/W TJMAX = 125°C, θJA = 43°C/W, θJC = 5.5°C/W EXPOSED PAD (PIN 13) IS GND, MUST BE SOLDERED TO PCB FOR EXPOSED PAD (PIN 9) IS GND, MUST BE SOLDERED TO PCB OPTIMAL THERMAL PERFORMANCE
orDer inForMaTion http://www.linear.com/product/LTC3624#orderinfo LEAD FREE FINISH TAPE AND REEL PART MARKING* PACKAGE DESCRIPTION TEMPERATURE RANGE
LTC3624EDD#PBF LTC3624EDD#TRPBF LGJF 8-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C LTC3624IDD#PBF LTC3624IDD#TRPBF LGJF 8-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C LTC3624EMSE#PBF LTC3624EMSE#TRPBF 3624 12-Lead Plastic MSOP –40°C to 125°C LTC3624IMSE#PBF LTC3624IMSE#TRPBF 3624 12-Lead Plastic MSOP –40°C to 125°C LTC3624HMSE#PBF LTC3624HMSE#TRPBF 3624 12-Lead Plastic MSOP –40°C to 150°C LTC3624EDD-3.3#PBF LTC3624EDD-3.3#TRPBF LGRG 8-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C LTC3624IDD-3.3#PBF LTC3624IDD-3.3#TRPBF LGRG 8-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C LTC3624EMSE-3.3#PBF LTC3624EMSE-3.3#TRPBF 362433 12-Lead Plastic MSOP –40°C to 125°C LTC3624IMSE-3.3#PBF LTC3624IMSE-3.3#TRPBF 362433 12-Lead Plastic MSOP –40°C to 125°C LTC3624HMSE-3.3#PBF LTC3624HMSE-3.3#TRPBF 362433 12-Lead Plastic MSOP –40°C to 150°C LTC3624EDD-5#PBF LTC3624EDD-5#TRPBF LGRD 8-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C LTC3624IDD-5#PBF LTC3624IDD-5#TRPBF LGRD 8-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C LTC3624EMSE-5#PBF LTC3624EMSE-5#TRPBF 36245 12-Lead Plastic MSOP –40°C to 125°C LTC3624IMSE-5#PBF LTC3624IMSE-5#TRPBF 36245 12-Lead Plastic MSOP –40°C to 125°C LTC3624HMSE-5#PBF LTC3624HMSE-5#TRPBF 36245 12-Lead Plastic MSOP –40°C to 150°C LTC3624EDD-2#PBF LTC3624EDD-2#TRPBF LGMN 8-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C LTC3624IDD-2#PBF LTC3624IDD-2#TRPBF LGMN 8-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C LTC3624EMSE-2#PBF LTC3624EMSE-2#TRPBF 36242 12-Lead Plastic MSOP –40°C to 125°C LTC3624IMSE-2#PBF LTC3624IMSE-2#TRPBF 36242 12-Lead Plastic MSOP –40°C to 125°C 36242fd 2 For more information www.linear.com/LTC3624 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Operation Applications Information Package Description Revision History Typical Application Related Parts
