Datasheet ADP5080 (Analog Devices) - 2
DescriptionHigh Efficiency Integrated Power Solution for Multicell Lithium Ion Applications
Pages / Page64 / 2 — ADP5080. Data Sheet. TABLE OF CONTENTS. REVISION HISTORY. 4/14—Revision …
RevisionA
ADP5080. Data Sheet. TABLE OF CONTENTS. REVISION HISTORY. 4/14—Revision A: Initial Version
ADP5080 Data Sheet TABLE OF CONTENTS REVISION HISTORY 4/14—Revision A: Initial Version
link to page 1 link to page 1 link to page 1 link to page 1 link to page 2 link to page 3 link to page 4 link to page 5 link to page 7 link to page 8 link to page 9 link to page 9 link to page 9 link to page 10 link to page 12 link to page 18 link to page 19 link to page 19 link to page 19 link to page 19 link to page 22 link to page 27 link to page 27 link to page 28 link to page 29 link to page 29 link to page 29 link to page 30 link to page 31 link to page 31 link to page 32 link to page 33 link to page 34 link to page 34 link to page 34 link to page 36 link to page 36 link to page 37 link to page 38 link to page 38 link to page 38 link to page 38 link to page 38 link to page 40 link to page 40 link to page 41 link to page 61 link to page 63 link to page 63
Features .. 1 Channel 7: High Voltage LDO Regulator ... 29 Applications ... 1 Charge Pump .. 29 Functional Block Diagram .. 1 Enabling and Disabling the Output Channels.. 30 General Description ... 1 Power-Good Function ... 31 Revision History ... 2 Fault Function ... 31 Specifications ... 3 Undervoltage Protection (UVP) .. 32 Housekeeping Block Specifications ... 4 Overvoltage Protection (OVP) ... 33 DC-to-DC Converter Block Specifications .. 5 Applications Information .. 34 Linear Regulator Block Specifications ... 7 Component Selection for the Buck and Buck Boost I2C Interface Timing Specifications ... 8 Regulators .. 34 Absolute Maximum Ratings .. 9 Component Selection for the LDO Regulators .. 36 Thermal Resistance .. 9 PCB Layout Recommendations ... 36 ESD Caution .. 9 Thermal Considerations .. 37 Pin Configuration and Function Descriptions ... 10 I2C Interface .. 38 Typical Performance Characteristics ... 12 SDA and SCL Pins .. 38 Application Circuit ... 18 I2C Address .. 38 Theory of Operation .. 19 Self-Clearing Register Bits ... 38 UVLO and POR .. 19 I2C Interface Timing Diagrams .. 38 Discharge Switch .. 19 Control Register Information ... 40 Keep-Alive LDO Regulators ... 19 Control Register Map .. 40 DC-to-DC Converter Channels ... 22 Control Register Details .. 41 Light Load and Other Modes of Operation Factory Default Options .. 61 for the DC-to-DC Converter Channels .. 27 Outline Dimensions ... 63 Switching Clock .. 28 Ordering Guide .. 63 Soft Start Function ... 29
Rev. A | Page 2 of 64 Document Outline Features Applications Functional Block Diagram General Description Table of Contents Revision History Specifications Housekeeping Block Specifications DC-to-DC Converter Block Specifications Linear Regulator Block Specifications I2C Interface Timing Specifications Timing Diagram Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Application Circuit Theory of Operation UVLO and POR Undervoltage Lockout (UVLO) Power-On Reset (POR) Discharge Switch Keep-Alive LDO Linear Regulators LDO1 VISW1 Input Current Limit for LDO1 Discharge Switch for LDO1 LDO2 VISW2 Input Current Limit for LDO2 Discharge Switch for LDO2 DC-to-DC Converter Channels Channel 1, Channel 2, and Channel 3: Buck Regulators with Flex-Mode Architecture Selecting the Output Voltage, Channel 1 to Channel 3 Current-Limit Protection, Channel 1 to Channel 3 Discharge Switch, Channel 1 to Channel 3 Gate Scaling (Channel 1 Only) Dynamic Voltage Scaling (DVS) Function Channel 4 and Channel 5: Current Mode Buck Regulators Selecting the Output Voltage, Channel 4 and Channel 5 Current-Limit Protection, Channel 4 and Channel 5 Discharge Switch, Channel 4 and Channel 5 Channel 6: Buck or Buck Boost Regulator Buck Only Configuration Buck Boost Configuration Selecting the Output Voltage, Channel 6 Current-Limit Protection, Channel 6 Discharge Switch, Channel 6 Light Load and Other Modes of Operation for the DC-to-DC Converter Channels Slew Rate Adjustment Forced PWM (FPWM) Mode Auto DCM Auto PSM Selecting Light Load Switching Modes Switching Clock External Synchronization Mode Selecting the Internal Clock Frequency Selecting the External Resistor Phase Shifting CLKO Pin Soft Start Function Channel 7: High Voltage LDO Regulator Selecting the Output Voltage, Channel 7 Discharge Switch, Channel 7 Charge Pump Charge Pump Switching Frequency Capacitor Selection Protection Diode Using the Charge Pump as the Channel 7 Input Supply Enabling and Disabling the Output Channels Sequencer Mode Manual Mode EN Function EN34 Function Power-Good Function Fault Function Undervoltage Protection (UVP) UVP Detection Delay Channel 5 Standalone Undervoltage Detection Option Recovering from UVP Overvoltage Protection (OVP) OVP Detection Delay Recovering from OVP Applications Information Component Selection for the Buck and Buck Boost Regulators Setting the Output Voltage (Adjustable Mode Channels) Selecting the Inductor Selecting the Input Capacitor Selecting the Output Capacitor Component Selection for the LDO Regulators Selecting the Capacitors PCB Layout Recommendations Sensitive Signal Treatment Grounding External Component Placement and Signal Routing Thermal Considerations I2C Interface SDA and SCL Pins I2C Address Self-Clearing Register Bits I2C Interface Timing Diagrams Control Register Information Control Register Map CONTROL REGISTER DETAILS Register 1: DSCG (Discharge Switch Control), Address 0x01 Register 2: SFTTIM1234 (Soft Start Time for Channel 1, Channel 2, Channel 3, and Channel 4), Address 0x02 Register 3: SFTTIM567 (Soft Start Time for Channel 5, Channel 6, and Channel 7), Address 0x03 Register 4: EN_DLY12 (Enable Delay Time for Channel 1 and Channel 2), Address 0x04 Register 5: EN_DLY34 (Enable Delay Time for Channel 3 and Channel 4), Address 0x05 Register 6: EN_DLY56 (Enable Delay Time for Channel 5 and Channel 6), Address 0x06 Register 7: EN_DLY7 (Enable Delay Time for Channel 7), Address 0x07 Register 8: DIS_DLY12 (Disable Delay Time for Channel 1 and Channel 2), Address 0x08 Register 9: DIS_DLY34 (Disable Delay Time for Channel 3 and Channel 4), Address 0x09 Register 10: DIS_DLY56 (Disable Delay Time for Channel 5 and Channel 6), Address 0x0A Register 11: DIS_DLY7 (Disable Delay Time for Channel 7), Address 0x0B Register 12: VID1 (Output Voltage for Channel 1), Address 0x0C Register 13: VID23 (Output Voltage for Channel 2 and Channel 3), Address 0x0D Register 14: VID45 (Output Voltage for Channel 4 and Channel 5), Address 0x0E Register 15: VID6 (Output Voltage for Channel 6), Address 0x0F Register 16: VID7_LDO12 (Output Voltage for Channel 7, LDO1, and LDO2), Address 0x10 Register 17: DVS12 (DVS Control for Channel 1 and Channel 2), Address 0x11 Register 18: SEL_FREQ (Switching Frequency for Channel 1 to Channel 6), Address 0x12 Register 19: SEL_FREQ_CP (Charge Pump Frequency), Address 0x13 Register 20: SEL_PHASE (Switching Phase for Channel 1 to Channel 6), Address 0x14 Register 23: PROT_DLY (Undervoltage/Overvoltage Protection Delay Times), Address 0x17 Register 24: PWRG (Power-Good Status), Address 0x18 Register 25: MASK_PWRG (Power-Good Masked Channels), Address 0x19 Register 26: UVPST (Undervoltage Protection Status), Address 0x1A Register 27: OVPST (Overvoltage Protection Status), Address 0x1B Register 28: AUTO-PSM (Auto PSM or Forced PWM Mode for Channel 1 to Channel 6), Address 0x1C Register 29: SEQ_MODE (Sequencer Mode), Address 0x1D Register 30: ADJ_BST_VTH6 (Adjust Boost Kick-In Threshold and Regulation Mode for Channel 6), Address 0x1E Register 31: OPT_SR_ADJ (Slew Rate Adjustment for Channel 1 to Channel 6), Address 0x1F Register 32: DCM56_GSCAL1 (Auto DCM for Channel 5 and Channel 6, Gate Scaling for Channel 1), Address 0x20 Register 33: SEL_INP_LDO12 (Input Selection for LDO1 and LDO2), Address 0x21 Register 34: SEL_IND_UV5 (Independent UVP Control for Channel 5), Address 0x22 Register 35: OPTION_SEL (Channel 1 Output Voltage Reduction, Disable Delay Time Increase, EN34 Function), Address 0x23 Register 48: PCTRL (Channel Enable Control), Address 0x30 Factory Default Options Outline Dimensions Ordering Guide
