20 V, 4 A synchronous Step-Down Regulator with Low-Side Driver
Pages / Page
28 /8 — ADP2380. Data Sheet. 4.5. 1.30. RISING. FALLING. 4.4. 1.25. 4.3. (V). D …
PDF / 946 Kb
ADP2380. Data Sheet. 4.5. 1.30. RISING. FALLING. 4.4. 1.25. 4.3. (V). D L. 4.2. D ( L 1.20. ESH. 4.1. R H. 1.15. HRE. 4.0. IN T. 3.9. O 1.10. PVI. 3.8. 1.05. 3.7. 3.6. 1.00
ADP2380Data Sheet4.51.30RISINGRISINGFALLING4.4FALLING1.254.3)(V)VD L4.2D ( L 1.20OHOESH4.1SR H1.15HRET4.0OIN TVLPU3.9O 1.10NLPVIUV3.81.053.73.61.00 1 –40–20020406080100120 010 –40–20020406080100120 1 0 TEMPERATURE (°C) 09939- TEMPERATURE (°C) 09939- Figure 10. PVIN UVLO Threshold vs. Temperature Figure 13. UVLO Pin Threshold vs. Temperature 3.36066043.2V)(μA) NT602E (m3.1G A LTCURREO600P -U3.0L LDBACK V598E ESS PUF2.95962.8594–40–20020406080100120 012 –40–20020406080100120 013 TEMPERATURE (°C) 09939- TEMPERATURE (°C) 09939- Figure 11. SS Pin Pull-Up Current vs. Temperature Figure 14. FB Voltage vs. Temperature 530 R8.4OSC = 100kΩ8.35208.2)510kHz8.1(E (V)YG ANC500LT8.0UE QVOREEG7.9F490VR7.84807.7470–40–200204060801001207.6 014 –40–20020406080100120 015 TEMPERATURE (°C) 09939- TEMPERATURE (°C) 09939- Figure 12. Frequency vs. Temperature Figure 15. VREG Voltage vs. Temperature Rev. 0 | Page 8 of 28 Document Outline Features Applications Typical Applications Circuit General Description Revision History Specifications Absolute Maximum Ratings Thermal Information ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Functional Block Diagram Theory of Operation Control Scheme Internal Regulator (VREG) Bootstrap Circuitry Low-Side Driver Oscillator Synchronization Enable and Soft Start Power Good Peak Current-Limit and Short-Circuit Protection Overvoltage Protection (OVP) Undervoltage Lockout (UVLO) Thermal Shutdown Applications Information Input Capacitor Selection Output Voltage Setting Voltage Conversion Limitations Inductor Selection Output Capacitor Selection Low-Side Power Device Selection Programming Input Voltage UVLO Compensation Design Compensation Network Between COMP and GND Compensation Network Between COMP and FB ADIsimPower Design Tool Design Example Output Voltage Setting Frequency Setting Inductor Selection Output Capacitor Selection Low-Side MOSFET Selection Compensation Components Soft Start Time Program Input Capacitor Selection Recommended External Components Circuit Board Layout Recommendations Typical Applications Circuits Outline Dimensions Ordering Guide
