Datasheet LTC3633A-2, LTC3633A-3 (Analog Devices) - 2
Description | Dual Channel 3A, 20V Monolithic Synchronous Step-Down Regulator |
Pages / Page | 28 / 2 — ABSOLUTE MAXIMUM RATINGS (Note 1). PIN CONFIGURATION. ORDER INFORMATION … |
File Format / Size | PDF / 424 Kb |
ABSOLUTE MAXIMUM RATINGS (Note 1). PIN CONFIGURATION. ORDER INFORMATION LEAD FREE FINISH. TAPE AND REEL. PART MARKING*
LTC3633A-2/LTC3633A-3
PVIN1, PVIN2, SVIN .. –0.3V to 20V RUN1 ... –0.3V to SVIN + 0.3V PGOOD1, PGOOD2, VON1, VON2 ... –0.3V to 18V RUN2 ... –0.3V to 20V BOOST1, BOOST2 .. –0.3V to 23V Operating Junction Temperature Range BOOST1-SW1, BOOST2-SW2 ... –0.3V to 3.6V (Notes 3, 4) .. –40°C to 125°C INTVCC, TRACKSS1, TRACKSS2 .. –0.3V to 3.6V Storage Temperature Range ... –65°C to 150°C ITH1, ITH2, RT, MODE/SYNC ..–0.3V to INTVCC + 0.3V VFB1, VFB2, PHMODE. ..–0.3V to INTVCC + 0.3V
PIN CONFIGURATION
TOP VIEW TOP VIEW ITH1 1 28 VON1 TRACKSS1 2 27 SW1 V FB1 TRACKSS1 ITH1 V ON1 SW1 SW1 28 27 26 25 24 23 V 3 26 FB1 SW1 PGOOD1 1 22 PV PGOOD1 4 PV IN1 25 IN1 PHMODE 2 21 PVIN1 PHMODE 5 24 PVIN1 RUN1 3 20 SVIN RUN1 6 23 SVIN MODE/SYNC 4 19 BOOST1 29 MODE/SYNC 7 29 22 BOOST1 RT 5 PGND 18 INTV PGND CC RT 8 21 INTVCC RUN2 6 17 BOOST2 RUN2 9 20 BOOST2 SGND 7 16 PVIN2 SGND 10 19 PVIN2 PGOOD2 8 15 PVIN2 PGOOD2 11 18 PVIN2 9 10 11 12 13 14 V 12 17 FB2 SW2 V FB2 ITH2 V ON2 SW2 SW2 TRACKSS2 13 16 SW2 ITH2 14 15 V TRACKSS2 ON2 UFD PACKAGE FE PACKAGE 28-LEAD (4mm × 5mm) PLASTIC QFN 28-LEAD PLASTIC TSSOP TJMAX = 125°C, θJA = 43°C/W TJMAX = 125°C, θJA = 25°C/W EXPOSED PAD (PIN 29) IS PGND, MUST BE SOLDERED TO PCB EXPOSED PAD (PIN 29) IS PGND, MUST BE SOLDERED TO PCB
LTC3633AEUFD-2#PBF LTC3633AEUFD-2#TRPBF 633A2 28-Lead (4mm × 5mm) Plastic QFN –40°C to 125°C LTC3633AIUFD-2#PBF LTC3633AIUFD-2#TRPBF 633A2 28-Lead (4mm × 5mm) Plastic QFN –40°C to 125°C LTC3633AEFE-2#PBF LTC3633AEFE-2#TRPBF LTC3633AFE-2 28-Lead Plastic TSSOP –40°C to 125°C LTC3633AIFE-2#PBF LTC3633AIFE-2#TRPBF LTC3633AFE-2 28-Lead Plastic TSSOP –40°C to 125°C LTC3633AEUFD-3#PBF LTC3633AEUFD-3#TRPBF 633A3 28-Lead (4mm × 5mm) Plastic QFN –40°C to 125°C LTC3633AIUFD-3#PBF LTC3633AIUFD-3#TRPBF 633A3 28-Lead (4mm × 5mm) Plastic QFN –40°C to 125°C LTC3633AEFE-3#PBF LTC3633AEFE-3#TRPBF LTC3633AFE-3 28-Lead Plastic TSSOP –40°C to 125°C LTC3633AIFE-3#PBF LTC3633AIFE-3#TRPBF LTC3633AFE-3 28-Lead Plastic TSSOP –40°C to 125°C Consult LTC Marketing for parts specified with wider operating temperature ranges. *The temperature grade is identified by a label on the shipping container. Consult LTC Marketing for information on non-standard lead based finish parts. For more information on lead free part marking, go to: http:/ www.linear.com/leadfree/ For more information on tape and reel specifications, go to: http://www.linear.com/tapeandreel/ 3633a23fb 2 For more information www.linear.com/LTC3633A-2 Document Outline Description Typical Application Absolute Maximum Ratings Pin Configuration Electrical Characteristics Typical Performance Characteristics Pin Functions Operation Applications Information Package Description Typical Application Related Parts
