Datasheet LTC3600 (Analog Devices) - 2
Description15V, 1.5A Synchronous Rail-to-Rail Single Resistor Step-Down Regulator
Pages / Page28 / 2 — absoluTe MaxiMuM raTings (Notes 1, 5). pin conFiguraTion. orDer …
File Format / SizePDF / 852 Kb
absoluTe MaxiMuM raTings (Notes 1, 5). pin conFiguraTion. orDer inForMaTion http://www.linear.com/product/LTC3600#orderinfo
absoluTe MaxiMuM raTings (Notes 1, 5) pin conFiguraTion orDer inForMaTion http://www.linear.com/product/LTC3600#orderinfo
LTC3600
VIN, SW Voltage ... –0.3V to 16V ITH, RT Voltage ...–0.3V to INTVCC SW Transient Voltage (Note 6) ...–2V to 21V MODE/SYNC, PGFB, PGOOD Voltage ..–0.3V to INTVCC VOUT, ISET Voltage ..0V to VIN Operating Junction Temperature Range BOOST Voltage ..–0.3V to VIN + INTVCC (Notes 2, 5) .. –40°C to 125°C RUN Voltage..–0.3V to 12V MSE Package Lead Temperature INTVCC Voltage .. –0.3V to 7V (Soldering, 10 sec) ..300°C
pin conFiguraTion
TOP VIEW TOP VIEW ISET 1 12 PGOOD ISET 1 12 PGOOD ITH 2 11 VOUT ITH 2 11 VOUT RT 3 13 10 INTVCC RT 3 13 10 INTVCC GND PGFB 4 9 BOOST PGFB 4 GND 9 BOOST RUN 5 8 V RUN 5 8 V IN IN MODE/SYNC 6 7 SW MODE/SYNC 6 7 SW DD PACKAGE MSE PACKAGE 12-LEAD (3mm × 3mm) PLASTIC DFN 12-LEAD PLASTIC MSOP T T JMAX = 125°C, θJA = 43°C/W JMAX = 125°C, θJA = 55°C/W EXPOSED PAD (PIN 13) IS GND, MUST BE SOLDERED TO PCB EXPOSED PAD (PIN 13) IS GND, MUST BE SOLDERED TO PCB
orDer inForMaTion http://www.linear.com/product/LTC3600#orderinfo LEAD FREE FINISH TAPE AND REEL PART MARKING* PACKAGE DESCRIPTION TEMPERATURE RANGE
LTC3600EDD#PBF LTC3600EDD#TRPBF LFXB 12-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C LTC3600IDD#PBF LTC3600IDD#TRPBF LFXB 12-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C LTC3600EMSE#PBF LTC3600EMSE#TRPBF 3600 12-Lead Plastic MSOP –40°C to 125°C LTC3600IMSE#PBF LTC3600IMSE#TRPBF 3600 12-Lead Plastic MSOP –40°C to 125°C Consult LTC Marketing for parts specified with wider operating temperature ranges. *The temperature grade is identified by a label on the shipping container. Consult LTC Marketing for information on non-standard lead based finish parts. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifications, go to: http://www.linear.com/tapeandreel/. Some packages are available in 500 unit reels through designated sales channels with #TRMPBF suffix. 3600fd 2 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Functional Diagram Operation Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
