Datasheet LTC3613 (Analog Devices) - 9
Description24V, 15A Monolithic Step Down Regulator with Differential Output Sensing
Pages / Page36 / 9 — PIN FUNCTIONS. RUN (Pin 26):. SVIN (Pin 32):. EXTVCC (Pin 30):. INTV. CC …
File Format / SizePDF / 464 Kb
PIN FUNCTIONS. RUN (Pin 26):. SVIN (Pin 32):. EXTVCC (Pin 30):. INTV. CC (Pins 33, 34):. MODE/PLLIN (Pin 31):. PGND (Pins 36-44):
PIN FUNCTIONS RUN (Pin 26): SVIN (Pin 32): EXTVCC (Pin 30): INTV CC (Pins 33, 34): MODE/PLLIN (Pin 31): PGND (Pins 36-44):
LTC3613
Digital Run Control Input. RUN self biases detected or MODE/PLLIN is tied to INTVCC, forced continu- high with an internal 1.3μA pull-up. Forcing RUN below ous mode operation is selected. Tying this pin to SGND 1.2V disables switching. Taking RUN below 0.75V shuts allows discontinuous pulse-skipping mode operation at down all bias and places the LTC3613 into micropower light loads. shutdown mode of approximately 15μA.
SVIN (Pin 32):
Signal Input Supply. This pin powers the
EXTVCC (Pin 30):
External VCC Input. When EXTVCC exceeds internal control circuitry. 4.6V, an internal switch connects this pin to INTVCC and
INTV
shuts down the internal regulator so that the controller and
CC (Pins 33, 34):
Internal 5.3V Regulator Output. The driver and control circuits are powered from this voltage. gate drive power is drawn from EXTVCC. EXTVCC should Decouple this pin to power ground with a minimum of not exceed VIN. 4.7μF ceramic capacitor (CVCC). The anode of the Schottky
External Clock Synchronization diode, DB, connects to this pin. Input and/or Forced Continuous Mode Input. When an
PGND (Pins 36-44):
Power Ground Connection. Connect external clock is applied to this pin, the rising switching this pin as close as practical to the (–) terminal of C cycle will be synchronized with the rising edge of the VCC and the (–) terminal of C external clock. Additionally, this pin determines operation IN. under light load conditions. When either a clock input is 3613fa 9
