Datasheet ADP5042 (Analog Devices) - 5
Description | Micro PMU with 0.8 A Buck, Two 300 mA LDOs, Supervisory, Watchdog and Manual Reset |
Pages / Page | 30 / 5 — Data Sheet. ADP5042. BUCK SPECIFICATIONS. Table 3. Parameter. Test … |
Revision | B |
File Format / Size | PDF / 1.6 Mb |
Data Sheet. ADP5042. BUCK SPECIFICATIONS. Table 3. Parameter. Test Conditions/Comments. Min. Typ. Max. Unit. LDO1, LDO2 SPECIFICATIONS
Data Sheet ADP5042 BUCK SPECIFICATIONS
AVIN, VIN1 = 3.6 V, VOUT1 = 1.8 V, TJ= −40°C to +125°C for minimum/maximum specifications, L = 1 µH, COUT = 10 µF, and TA = 25°C for typical specifications, unless otherwise noted.1
Table 3. Parameter Test Conditions/Comments Min Typ Max Unit
INPUT CHARACTERISTICS Input Voltage Range (VIN1) 2.3 5.5 V OUTPUT CHARACTERISTICS Output Voltage Accuracy PWM mode, TA= 25 °C , ILOAD = 100 mA −1 +1 % PWM mode −2 +2 % VIN1 = 2.3 V to 5.5 V, PWM mode, −3 +3 % ILOAD = 1 to 800 mA PWM TO POWER SAVE MODE CURRENT THRESHOLD 100 mA INPUT CURRENT CHARACTERISTICS DC Operating Current ILOAD = 0 mA, device not switching 21 35 μA Shutdown Current ENx = 0 V, TA = TJ = −40°C to +125°C 0.2 1.0 μA SW CHARACTERISTICS SW On Resistance PFET 180 240 mΩ PFET, AVIN = VIN1 = 5 V 140 190 mΩ NFET 170 235 mΩ NFET, AVIN = VIN1 = 5 V 150 210 mΩ Current Limit PFET switch peak current limit 1100 1360 1600 mA ACTIVE PULL-DOWN EN1 = 0 V 75 Ω OSCILLATOR FREQUENCY 2.5 3.0 3.5 MHz START-UP TIME 250 μs 1 All limits at temperature extremes are guaranteed via correlation using standard statistical quality control (SQC).
AVIN = 3.6 V, VIN2, VIN3 = (VOUT3 + 0.2 V) or 2.3 V, whichever is greater; AVIN, VIN1 ≥ VIN2, VIN3; IOUT = 10 mA; CIN = COUT = 1 µF; TA = 25°C, unless otherwise noted.
Table 4. Parameter Symbol Conditions Min Typ Max Unit
INPUT VOLTAGE RANGE VIN2, VIN3 TJ = −40°C to +125°C 1.7 5.5 V OPERATING SUPPLY CURRENT (per IGND IOUT = 0 µA, VOUT = 3.3 V 15 µA LDO) IOUT = 0 µA, VOUT = 3.3 V, TJ = −40°C to +125°C 50 µA IOUT = 10 mA 67 µA IOUT = 10 mA, TJ = −40°C to +125°C 105 µA IOUT = 200 mA 100 µA IOUT = 200 mA, TJ = −40°C to +125°C 245 µA FIXED OUTPUT VOLTAGE ACCURACY VOUT2, VOUT3 IOUT = 10 mA −1 +1 % 100 µA < IOUT < 300 mA −2 +2 % VIN2, VIN3 = (VOUT2, VOUT3 + 0.5 V) to 5.5 V 100 µA < IOUT < 300 mA −3 +3 % VIN2, VIN3 = (VOUT2, VOUT3 + 0.5 V) to 5.5 V TJ = −40°C to +125°C REGULATION Line Regulation ∆VOUT2/∆VIN2 VIN2, VIN3 = (VOUT2, VOUT3 + 0.5 V) to 5.5 V −0.03 +0.03 %/V ∆VOUT3/∆VIN3 IOUT3 = 1 mA TJ = −40°C to +125°C Rev. B | Page 5 of 30 Document Outline FEATURES HIGH LEVEL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS GENERAL SPECIFICATION SUPERVISORY SPECIFICATION BUCK SPECIFICATIONS LDO1, LDO2 SPECIFICATIONS INPUT AND OUTPUT CAPACITOR, RECOMMENDED SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL DATA THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION POWER MANAGEMENT UNIT Thermal Protection Undervoltage Lockout Enable/Shutdown BUCK SECTION Control Scheme PWM Mode Power Save Mode (PSM) PSM Current Threshold Short-Circuit Protection Soft Start Current Limit 100% Duty Operation LDO SECTION SUPERVISORY SECTION Reset Output Manual Reset Input Watchdog 1 Input Watchdog 2 Input Watchdog Status Indicator APPLICATIONS INFORMATION BUCK EXTERNAL COMPONENT SELECTION Inductor Output Capacitor Input Capacitor LDO CAPACITOR SELECTION Output Capacitor Input Bypass Capacitor Input and Output Capacitor Properties SUPERVISORY SECTION Watchdog 1 Input Current Negative-Going VCC Transients Watchdog Software Considerations PCB LAYOUT GUIDELINES EVALUATION BOARD SCHEMATICS AND ARTWORK SUGGESTED LAYOUT BILL OF MATERIALS APPLICATION DIAGRAM FACTORY PROGRAMMABLE OPTIONS OUTLINE DIMENSIONS ORDERING GUIDE
