Datasheet LT3688 (Analog Devices) - 2
DescriptionDual 800mA Step-Down Switching Regulator with Power-On Reset and Watchdog Timer
Pages / Page28 / 2 — ABSOLUTE MAXIMUM RATINGS. (Note 1). PIN CONFIGURATION. ORDER INFORMATION …
File Format / SizePDF / 430 Kb
ABSOLUTE MAXIMUM RATINGS. (Note 1). PIN CONFIGURATION. ORDER INFORMATION LEAD FREE FINISH. TAPE AND REEL. PART MARKING*
ABSOLUTE MAXIMUM RATINGS (Note 1) PIN CONFIGURATION ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING*
LT3688
VIN, EN/UVLO, CONFIG Voltage (Note 2) ...36V Operating Junction Temperature Range (Note 3) BST Voltage ..55V LT3688E, LT3688I ..–40°C to 125°C BST above SW Voltage ...30V LT3688H ..–40°C to 150°C BIAS Voltage ...30V Maximum Junction Temperature WDE, WDI, RST, WDO Voltage ...6V LT3688E, LT3688I ... 125°C FB, RT , SYNC, RUN/SS Voltage ..6V LT3688H ... 150°C CWDT , CPOR Voltage ..3V Storage Temperature Range ...–65°C to 150°C Lead Temperature (Soldering, 10 sec) FE Package ... 300°C
PIN CONFIGURATION
TOP VIEW TOP VIEW FB1 1 24 EN/UVLO RUN/SS1 2 23 SYNC WDT POR1 POR2 C C BIAS C WDI WDE BST1 3 22 RT 24 23 22 21 20 19 SW1 4 21 C WDO WDT RT 1 18 DA1 5 20 C SYNC 2 17 RST1 POR1 RST2 V 6 19 EN/UVLO 3 16 IN BIAS 25 25 GND FB1 4 GND 15 FB2 CONFIG 7 18 CPOR2 RUN/SS1 5 14 RUN/SS2 DA2 8 17 WDI BST1 6 13 BST2 SW2 9 16 WDE BST2 10 15 WDO 7 8 9 10 11 12 IN RUN/SS2 11 14 RST1 SW1 DA1 V DA2 SW2 FB2 12 13 RST2 CONFIG FE PACKAGE UF PACKAGE 24-LEAD PLASTIC TSSOP 24-LEAD (4mm × 4mm) PLASTIC QFN θJA = 38°C/W θJA = 37°C/W EXPOSED PAD (PIN 25) IS GND, MUST BE ELECTRICALLY CONNECTED TO PCB EXPOSED PAD (PIN 25) IS GND, MUST BE ELECTRICALLY CONNECTED TO PCB
LT3688EFE#PBF LT3688EFE#TRPBF LT3688FE 24-Lead Plastic TSSOP –40°C to 125°C LT3688IFE#PBF LT3688IFE#TRPBF LT3688FE 24-Lead Plastic TSSOP –40°C to 125°C LT3688HFE#PBF LT3688HFE#TRPBF LT3688FE 24-Lead Plastic TSSOP –40°C to 150°C LT3688EUF#PBF LT3688EUF#TRPBF 3688 24-Lead (4mm × 4mm) Plastic QFN –40°C to 125°C LT3688IUF#PBF LT3688IUF#TRPBF 3688 24-Lead (4mm × 4mm) Plastic QFN –40°C to 125°C Consult LTC Marketing for parts specifi ed with wider operating temperature ranges. *The temperature grade is identifi ed by a label on the shipping container. Consult LTC Marketing for information on non-standard lead based fi nish parts. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifi cations, go to: http://www.linear.com/tapeandreel/ 3688f 2
