Datasheet ADP2302, ADP2303 (Analog Devices) - 4
Description3A, 700KHz NonSynchronous Step-Down DC-DC Switching Regulator
Pages / Page28 / 4 — ADP2302/ADP2303. Data Sheet. ABSOLUTE MAXIMUM RATINGS Table 2. THERMAL …
ADP2302/ADP2303. Data Sheet. ABSOLUTE MAXIMUM RATINGS Table 2. THERMAL RESISTANCE. Parameter MAX. Rating
ADP2302/ADP2303 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 2 THERMAL RESISTANCE Parameter MAX Rating
link to page 4
ADP2302/ADP2303 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 2. THERMAL RESISTANCE Parameter MAX Rating
θJA is specified for the worst-case conditions, that is, a device VIN, EN, PGOOD −0.3 V to +24 V soldered in a circuit board for surface-mount packages. SW −1.0 V to +24 V
Table 3. Thermal Resistance1
BST to SW −0.6 V to +6 V
Package Type θ
FB, NC −0.3 V to +6 V
JA Unit
Operating Junction Temperature Range −40°C to +125°C 8-Lead SOIC_N_EP 58.5 °C/W Storage Temperature Range −65°C to +150°C 1 JA is measured using natural convection on JEDEC 4-layer board. Soldering Conditions JEDEC J-STD-020
ESD CAUTION
Stresses above those listed under Absolute Maximum Ratings may cause permanent damage to the device. This is a stress rating only; functional operation of the device at these or any other conditions above those indicated in the operational section of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Absolute maximum ratings apply individually only, not in combination. Unless otherwise specified, all voltages are referenced to GND. Rev. A | Page 4 of 28 Document Outline Features Applications Typical Applications Circuit General Description Revision History Specifications Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Functional Block Diagram Theory of Operation Basic Operation PWM Mode Power Saving Mode Bootstrap Circuitry Precision Enable Integrated Soft Start Current Limit Short-Circuit Protection Undervoltage Lockout (UVLO) Thermal Shutdown (TSD) Overvoltage Protection (OVP) Power Good Control Loop Applications Information ADIsimPower Design Tool Programming Output Voltage Voltage Conversion Limitations Low Input Voltage Considerations Programming the Precision Enable Inductor Catch Diode Input Capacitor Output Capacitor Thermal Consideration Design Example Catch Diode Selection Inductor Selection Output Capacitor Selection Resistive Voltage Divider Selection Circuit Board Layout Recommendations Typical Application Circuits Outline Dimensions Ordering Guide
