Datasheet ADP2300, ADP2301 (Analog Devices) - 4
Description1.2 A, 20 V, 1.4 MHz non-synchronous step-down switching regulator
Pages / Page28 / 4 — ADP2300/ADP2301. Data Sheet. ABSOLUTE MAXIMUM RATINGS Table 2. Parameter. …
RevisionC
File Format / SizePDF / 616 Kb
ADP2300/ADP2301. Data Sheet. ABSOLUTE MAXIMUM RATINGS Table 2. Parameter. Rating. THERMAL RESISTANCE. Table 3. Thermal Resistance1
ADP2300/ADP2301 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 2 Parameter Rating THERMAL RESISTANCE Table 3 Thermal Resistance1
link to page 4
ADP2300/ADP2301 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 2. Parameter Rating THERMAL RESISTANCE
VIN, EN −0.3 V to +28 V θJA is specified for the worst-case conditions, that is, a device SW −1.0 V to +28 V soldered in a circuit board for surface-mount packages. BST to SW −0.6 V to +6 V BST −0.3 V to +28 V
FB −0.3 V to +3.3 V
Package Type θ θ Unit JA JC
Operating Junction Temperature Range −40°C to +125°C 6-Lead TSOT 186.02 66.34 °C/W Storage Temperature Range −65°C to +150°C 1 θ Soldering Conditions JEDEC J-STD-020 JA and θJC are measured using natural convection on a JEDEC 4-layer board.
ESD CAUTION
Stresses above those listed under Absolute Maximum Ratings may cause permanent damage to the device. This is a stress rating only; functional operation of the device at these or any other conditions above those indicated in the operational section of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Absolute maximum ratings apply individually only, not in combination. Unless otherwise specified, all voltages are referenced to GND. Rev. C | Page 4 of 28 Document Outline Features Applications Typical Applications Circuit General Description Revision History Specifications Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Functional Block Diagram Theory of Operation Basic Operation PWM Mode Power Saving Mode Bootstrap Circuitry Precision Enable Integrated Soft Start Current Limit Short-Circuit Protection Undervoltage Lockout (UVLO) Thermal Shutdown Control Loop Applications Information ADIsimPower Design Tool Programming the Output Voltage Voltage Conversion Limitations Low Input Voltage Considerations Programming the Precision Enable Inductor Catch Diode Input Capacitor Output Capacitor Thermal Considerations Design Example Switching Frequency Selection Catch Diode Selection Inductor Selection Output Capacitor Selection Resistive Voltage Divider Selection Circuit Board Layout Recommendations Typical Application Circuits Outline Dimensions Ordering Guide
