Datasheet LTC3601 (Analog Devices) - 2
Description1.5A, 15V Monolithic Synchronous Step-Down Regulator
Pages / Page26 / 2 — ABSOLUTE MAXIMUM RATINGS (Note 1). PIN CONFIGURATION. ORDER INFORMATION. …
File Format / SizePDF / 421 Kb
ABSOLUTE MAXIMUM RATINGS (Note 1). PIN CONFIGURATION. ORDER INFORMATION. LEAD FREE FINISH. TAPE AND REEL. PART MARKING*
ABSOLUTE MAXIMUM RATINGS (Note 1) PIN CONFIGURATION ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING*
LTC3601
VIN ... –0.3V to 16V SW, RUN .. –0.3V to VIN + 0.3V VIN Transient Voltage ..18V SW Source Current (DC) ...2A BOOST ...–0.3V to 18.6V Peak SW Source Current..3.5A BOOST-SW .. –0.3V to 3.6V Operating Junction Temperature Range INTVCC .. –0.3V to 3.6V (Notes 2, 3) ... –40°C to 125°C ITH, RT...–0.3V to INTVCC + 0.3V Storage Temperature Range .. –65°C to 125°C MODE/SYNC, FB ..–0.3V to INTVCC + 0.3V Lead Temperature (Soldering, 10 sec) TRACK ...–0.3V to INTVCC + 0.3V MSOP ...300°C PGOOD, VON ... –0.3V to 16V
PIN CONFIGURATION
TOP VIEW V IN V IN RUN TRACK TOP VIEW 16 15 14 13 SW 1 16 PGOOD MODE/SYNC 1 12 ITH SW 2 15 MODE/SYNC PGOOD 2 11 FB PGND 3 14 VIN 17 PGND 4 13 VIN 17 SW 3 10 RT BOOST 5 12 RUN INTV 6 11 TRACK SW 4 9 SGND CC V 7 ON 10 ITH 5 6 7 8 RT 8 9 FB MSE PACKAGE NC CC V ON 16-LEAD PLASTIC MSOP BOOST INTV UD PACKAGE TJMAX = 125°C, θJA = 38°C/W 16-LEAD (3mm × 3mm) PLASTIC QFN EXPOSED PAD (PIN 17) IS SGND, MUST BE SOLDERED TO PCB TJMAX = 125°C, θJA = 45°C/W EXPOSED PAD (PIN 17) IS PGND, MUST BE SOLDERED TO PCB
LTC3601EUD#PBF LTC3601EUD#TRPBF LFJC 16-Lead (3mm × 3mm) Plastic QFN –40°C to 125°C LTC3601IUD#PBF LTC3601IUD#TRPBF LFJC 16-Lead (3mm × 3mm) Plastic QFN –40°C to 125°C LTC3601EMSE#PBF LTC3601EMSE#TRPBF 3601 16-Lead Plastic MSOP –40°C to 125°C LTC3601IMSE#PBF LTC3601IMSE#TRPBF 3601 16-Lead Plastic MSOP –40°C to 125°C Consult LTC Marketing for parts specified with wider operating temperature ranges. *The temperature grade is identified by a label on the shipping container. Consult LTC Marketing for information on non-standard lead based finish parts. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifications, go to: http://www.linear.com/tapeandreel/ 3601fc 2 For more information www.linear.com/LTC3601 Document Outline Features Description Applications Typical Application Absolute Maximum Ratings Pin Configuration Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Operation Applications Information Related Parts
