LTC3605 operaTion PVIN/SVIN Voltage DifferentialProgramming Switching Frequency SVIN should be tied to PVIN with a low pass filter of 1Ω Connecting a resistor from the RT pin to SGND programs to 10Ω and 0.1μF. For applications where PVIN and SVIN the switching frequency from 800kHz to 4MHz according are tied to vastly different voltage potentials, though the to the following formula: output voltage will remain in regulation, there will be an 1.6e11 offset in the internal on-time generator such that if SVIN Frequency (Hz) = is different than PV R IN by more than 50% of the PVIN volt- T (W) age, the resulting switching frequency will deviate from The internal PLL has a synchronization range of ±30% the frequency programmed by the RT resistor and/or the around its programmed frequency. Therefore, during external clock synchronization frequency. In such applica- external clock synchronization be sure that the external tions, in order to return the switching frequency back to clock frequency is within this ±30% range of the RT pro- the original desired frequency, RT resistor value can be grammed frequency. adjusted accordingly. However, the better alternative is to tie the VON pin to a voltage different than that of VOUT Output Voltage Tracking and Soft-Start in order to negate the offset of the VIN differential. For instance, if SV The LTC3605 allows the user to program its output voltage IN is 6V and PVIN is 12V, the resulting switch- ing frequency may be slower than what’s programmed ramp rate by means of the TRACK/SS pin. An internal 2µA by the R pulls up the TRACK/SS pin to INTVCC. Putting an external T resistor. Tying the VON pin to a voltage half of V capacitor on TRACK/SS enables soft starting the output OUT will negate the VIN offset and return the switching frequency back to normal. to prevent current surge on the input supply. For output tracking applications, TRACK/SS can be externally driven Output Voltage Programming by another voltage source. From 0V to 0.6V, the TRACK/SS voltage will override the internal 0.6V reference input to the The output voltage is set by an external resistive divider error amplifier, thus regulating the feedback voltage to that according to the following equation: of TRACK/SS pins. During this start-up time, the LTC3605 VOUT = 0.6V • (1 + R2/R1) will operate in discontinuous mode. When TRACK/SS is above 0.6V, tracking is disabled and the feedback voltage The resistive divider allows the VFB pin to sense a fraction will regulate to the internal reference voltage. of the output voltage as shown in Figure 1. Output Power Good VOUT When the LTC3605’s output voltage is within the ±10% R2 C window of the regulation point, which is reflected back as FF FB a VFB voltage in the range of 0.54V to 0.66V, the output voltage is good and the PGOOD pin is pulled high with an LTC3605 R1 external resistor. Otherwise, an internal open-drain pull- SGND down device (12Ω) will pull the PGOOD pin low. To prevent 3605 F01 unwanted PGOOD glitches during transients or dynamic Figure 1. Setting the Output Voltage VOUT changes, the LTC3605’s PGOOD falling edge includes a blanking delay of approximately 52 switching cycles. 3605fh For more information www.linear.com/LTC3605 9 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Order Information Pin Configuration Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Operation Typical Applications Package Description Revision History Typical Application Related Parts
