Datasheet LTC3603 (Analog Devices) - 10
Description2.5A, 15V Monolithic Synchronous Step-Down Regulator
Pages / Page22 / 10 — applications inForMation. Operating Frequency. Inductor Core Selection. …
File Format / SizePDF / 284 Kb
applications inForMation. Operating Frequency. Inductor Core Selection. Inductor Selection
applications inForMation Operating Frequency Inductor Core Selection Inductor Selection
LTC3603
The basic LTC3603 application circuit is shown on the front A reasonable starting point for selecting the ripple current page of this data sheet. External component selection is is DIL = 0.4(IMAX), where IMAX is the maximum output determined by the maximum load current and begins with current. The largest ripple current occurs at the highest the selection of the inductor value and operating frequency VIN. To guarantee that the ripple current stays below a followed by CIN and COUT. specified maximum, the inductor value should be chosen according to the following equation:
Operating Frequency
Selection of the operating frequency is a trade-off between ⎛ V ⎞ ⎛ V ⎞ L = OUT OUT efficiency and component size. High frequency operation ⎜ ⎟ • 1– ⎜ ⎟ ⎝ fΔIL(MAX)⎠ ⎝ VIN(MAX)⎠ allows the use of smaller inductor and capacitor values. Operation at lower frequencies improves efficiency by The inductor value will also have an effect on Burst Mode reducing internal gate charge and switching losses but operation. The transition from low current operation requires larger inductance values and/or capacitance to begins when the peak inductor current falls below a level maintain low output ripple voltage. The operating frequency set by the burst clamp. Lower inductor values result in of the LTC3603 is determined by an external resistor that is higher ripple current which causes this to occur at lower connected between the RT pin and ground. The value of the load currents. This causes a dip in efficiency in the upper resistor sets the ramp current that is used to charge and range of low current operation. In Burst Mode operation, discharge an internal timing capacitor within the oscillator lower inductance values will cause the burst frequency and can be calculated by using the following equation: to increase. 1.15 • 1011
ROSC = – 10k f(Hz) Once the value for L is known, the type of inductor must be selected. High efficiency converters generally cannot Although frequencies as high as 3MHz are possible, the afford the core loss found in low cost powdered iron cores, minimum on-time of the LTC3603 imposes a minimum forcing the use of the more expensive ferrite cores. Actual limit on the operating duty cycle. The minimum on-time core loss is independent of core size for a fixed inductor is typically 95ns. Therefore, the minimum duty cycle is value but it is very dependent on the inductance selected. equal to 100 • 95ns • f(Hz). As the inductance increases, core losses decrease. Un-
Inductor Selection
fortunately, increased inductance requires more turns of wire and therefore copper losses will increase. For a given input and output voltage, the inductor value and operating frequency determine the ripple current. The Ferrite designs have very low core losses and are pre- ripple current DI ferred at high switching frequencies, so design goals can L increases with higher VIN and decreases with higher inductance. concentrate on copper loss and preventing saturation. Ferrite core material saturates hard, which means that ⎛ V ⎛ V ⎞ inductance collapses abruptly when the peak design current ΔI OUT ⎞ OUT L = is exceeded. This results in an abrupt increase in inductor ⎝⎜ fL ⎠⎟ • 1– ⎝⎜ VIN ⎠⎟ ripple current and consequent output voltage ripple. Do Having a lower ripple current reduces the ESR losses not allow the core to saturate! in the output capacitors and the output voltage ripple. Different core materials and shapes will change the Highest efficiency operation is achieved at low frequency size/current and price/current relationship of an inductor. with small ripple current. This, however, requires a large Toroid or shielded pot cores in ferrite or permalloy ma- inductor. terials are small and do not radiate energy but generally cost more than powdered iron core inductors with similar 3603fc 10 For more information www.linear.com/LTC3603
