Datasheet LTC3602 (Analog Devices) - 5
Description | 2.5A, 10V, Monolithic Synchronous Step-Down Regulator |
Pages / Page | 20 / 5 — TYPICAL PERFORMANCE CHARACTERISTICS. Minimum Peak Inductor Current. … |
File Format / Size | PDF / 230 Kb |
TYPICAL PERFORMANCE CHARACTERISTICS. Minimum Peak Inductor Current. Maximum Peak Inductor Current
LTC3602
TYPICAL PERFORMANCE CHARACTERISTICS Minimum Peak Inductor Current Maximum Peak Inductor Current Effi ciency vs Load Current, vs Burst Clamp Voltage vs Duty Cycle Burst Mode Operation
3.0 5 100 FIGURE 6 CIRCUIT V 2.5 IN = 5V 95 4 VIN = 9V 2.0 90 3 1.5 85 2 1.0 EFFICIENCY (%) 80 PEAK INDUCTOR CURRENT (A) 0.5 PEAK INDUCTOR CURRENT (A) 1 75 0 0 70 0.4 0.5 0.6 0.7 0.8 0.9 1.0 0 10 20 30 40 50 60 70 80 90 100 0.01 0.1 1 10 BURST CLAMP VOLTAGE (V) DUTY CYCLE (%) LOAD CURRENT (A) 3602 G12 3602 G13 3602 G14
Effi ciency vs Load Current, Forced Continuous Effi ciency vs Input Voltage Effi ciency vs Frequency
100 100 100 FIGURE 6 CIRCUIT FIGURE 6 CIRCUIT FIGURE 6 CIRCUIT 90 98 VIN = 7V 95 ILOAD = 1A ILOAD = 1A 80 V 96 IN = 5V 70 90 ILOAD = 2.5A 94 2.2μH 60 50 85 92 1μH 40 VIN = 9V 90 EFFICIENCY (%) EFFICIENCY (%) 80 EFFICIENCY (%) 30 88 4.7μH 20 75 86 10 0 70 84 0.01 0.1 1 10 4 5 6 7 8 9 10 0 500 1000 1500 2000 2500 3000 LOAD CURRENT (A) INPUT VOLTAGE (V) FREQUENCY (kHz) 3602 G15 3602 G16 3602 G17
5V LDO Output Voltage TRACK/SS Current Load Regulation vs Temperature vs Temperature
0.10 5.10 1.40 FIGURE 6 CIRCUIT V 5.08 IN = 7V 1.35 5.06 5.04 0.00 1.30 (%) 5.02 OUT /V 5.00 1.25 OUT 4.98 ΔV –0.10 1.20 4.96 LDO OUTPUT VOLTAGE (V) TRACK/SS CURRENT (μA) 4.94 1.15 4.92 –0.20 4.90 1.10 0 0.5 1 1.5 2 2.5 3 –50 –25 0 25 50 75 100 125 –50 –25 0 25 50 75 100 125 LOAD CURRENT (A) TEMPERATURE (oC) TEMPERATURE (oC) 3602 G18 3602 G19 3602 G20 3602fb 5
