Datasheet LTC3547B (Analog Devices) - 10
DescriptionDual Monolithic 300mA Synchronous Step-Down Regulator
Pages / Page16 / 10 — APPLICATIO S I FOR ATIO. Setting the Output Voltage. Table 2. Fixed …
File Format / SizePDF / 260 Kb
APPLICATIO S I FOR ATIO. Setting the Output Voltage. Table 2. Fixed Output Voltage Versions. Part Number. OUT1. VOUT2
APPLICATIO S I FOR ATIO Setting the Output Voltage Table 2 Fixed Output Voltage Versions Part Number OUT1 VOUT2
LTC3547B
U U W U APPLICATIO S I FOR ATIO Setting the Output Voltage
a load step occurs, VOUT immediately shifts by an amount equal to ΔI The LTC3547B regulates the V LOAD • ESR, where ESR is the effective series FB1 and VFB2 pins to 0.6V resistance of C during regulation. Thus, the output voltage is set by a OUT. ΔILOAD also begins to charge or dis- charge C resistive divider according to the following formula: OUT generating a feedback error signal used by the regulator to return VOUT to its steady-state value. During this recovery time, V V OUT can be monitored for overshoot OUT = 0.6V 1+ R2 (4) or ringing that would indicate a stability problem. R1 The initial output voltage step may not be within the band- Keeping the current small (< 5μA) in these resistors maxi- width of the feedback loop, so the standard second-order mizes effi ciency, but making it too small may allow stray overshoot/DC ratio cannot be used to determine the phase capacitance to cause noise problems or reduce the phase margin. In addition, feedback capacitors (C margin of the error amp loop. F1 and CF2) can be added to improve the high frequency response, as To improve the frequency response of the main control shown in Figure 1. Capacitor CF provides phase lead by loop, a feedback capacitor (CF) may also be used. Great creating a high frequency zero with R2 which improves care should be taken to route the VFB line away from noise the phase margin. sources, such as the inductor or the SW line. The output voltage settling behavior is related to the stability Fixed output versions of the LTC3547B (e.g. LTC3547B-1) of the closed-loop system and will demonstrate the actual include an internal resistive divider, eliminating the need overall supply performance. For a detailed explanation of for external resistors. The resistor divider is chosen such optimizing the compensation components, including a re- that the VFB input current is 3μA. For these versions, the view of control loop theory, refer to Application Note 76. VFB pin should be connected directly to VOUT. Table 2 lists In some applications, a more severe transient can be the fi xed output voltages available for the LTC3547B. caused by switching in loads with large (>1μF) input ca-
pacitors. The discharged input capacitors are effectively
Part Number V
put in parallel with C
OUT1 VOUT2
OUT, causing a rapid drop in VOUT. LTC3547B Adjustable Adjustable No regulator can deliver enough current to prevent this problem if the switch connecting the load has low resistance LTC3547B-1 1.8V 1.2V and is driven quickly. The solution is to limit the turn-on speed of the load switch driver. A Hot Swap™ controller
Checking Transient Response
is designed specifi cally for this purpose and usually in- corporates current limiting, short-circuit protection, and The regulator loop response can be checked by looking soft-starting. at the load transient response. Switching regulators take several cycles to respond to a step in load current. When Hot Swap is a trademark of Linear Technology Corporation. 3547bfb 10
