Datasheet LT3493-3 (Analog Devices) - 7
Description1.2A, 750kHz Step-Down Switching Regulator in 2mm × 3mm DFN
Pages / Page20 / 7 — OPERATIO (Refer to Block Diagram)
File Format / SizePDF / 391 Kb
LT3493-3
U OPERATIO (Refer to Block Diagram)
The LT3493-3 is a constant frequency, current mode step- An internal regulator provides power to the control cir- down regulator. A 750kHz oscillator enables an RS flip- cuitry. This regulator includes an undervoltage lockout to flop, turning on the internal 1.75A power switch Q1. An prevent switching when VIN is less than 6.8V. The SHDN amplifier and comparator monitor the current flowing pin is used to place the LT3493-3 in shutdown, discon- between the VIN and SW pins, turning the switch off when necting the output and reducing the input current to less this current reaches a level determined by the voltage at than 2µA. VC. An error amplifier measures the output voltage through The switch driver operates from either the input or from an external resistor divider tied to the FB pin and servos the the BOOST pin. An external capacitor and diode are used VC node. If the error amplifier’s output increases, more to generate a voltage at the BOOST pin that is higher than current is delivered to the output; if it decreases, less the input supply. This allows the driver to fully saturate the current is delivered. An active clamp (not shown) on the VC internal bipolar NPN power switch for efficient operation. node provides current limit. The VC node is also clamped to the voltage on the SHDN pin; soft-start is implemented The oscillator reduces the LT3493-3’s operating frequency by generating a voltage ramp at the SHDN pin using an when the voltage at the FB pin is low. This frequency external resistor and capacitor. foldback helps to control the output current during start- up and overload. 3493-3f 7
