Datasheet LT3481 (Analog Devices) - 3
Description36V, 2A, 2.8MHz Step-Down Switching Regulator with 50µA Quiescent Current
Pages / Page24 / 3 — The. ELECTRICAL CHARACTERISTICS. denotes the specifi cations which apply …
File Format / SizePDF / 315 Kb
The. ELECTRICAL CHARACTERISTICS. denotes the specifi cations which apply over the full operating
The ELECTRICAL CHARACTERISTICS denotes the specifi cations which apply over the full operating
LT3481
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. VIN = 10V, VRUNS/SS = 10V VBOOST = 15V, VBIAS = 3.3V unless otherwise noted. (Note 2) PARAMETER CONDITIONS MIN TYP MAX UNITS
Minimum Input Voltage ● 3 3.6 V Quiescent Current from VIN VRUN/SS = 0.2V 0.01 0.5 μA VBIAS = 3V, Not Switching ● 22 60 μA VBIAS = 0, Not Switching 75 120 μA Quiescent Current from BIAS VRUN/SS = 0.2V 0.01 0.5 μA VBIAS = 3V, Not Switching ● 50 120 μA VBIAS = 0, Not Switching 0 5 μA Minimum Bias Voltage 2.7 3 V Feedback Voltage 1.25 1.265 1.29 V ● 1.24 1.265 1.3 V FB Pin Bias Current (Note 3) VFB = 1.25V, VC = 0.4V ● 30 100 nA FB Voltage Line Regulation 4V < VIN < 34V 0.002 0.02 %/V Error Amp gm 330 μMho Error Amp Gain 800 VC Source Current 65 μA VC Sink Current 85 μA VC Pin to Switch Current Gain 3.5 A/V VC Clamp Voltage 2 V Switching Frequency RT = 8.66k 2.5 2.8 3.1 MHz RT = 29.4k 1.25 1.4 1.55 MHz RT = 187k 250 300 350 kHz Minimum Switch Off-Time ● 130 200 nS Switch Current Limit Duty Cycle = 5% 3.2 3.8 4.4 A Switch VCESAT ISW = 2A 360 mV Boost Schottky Reverse Leakage VSW = 10V, VBIAS = 0V 0.02 2 μA Minimum Boost Voltage (Note 4) ● 1.5 2.1 V BOOST Pin Current ISW = 1A 18 35 mA RUN/SS Pin Current VRUN/SS = 2.5V 5 10 μA RUN/SS Input Voltage High 2.5 V RUN/SS Input Voltage Low 0.2 V PG Threshold Offset from Feedback Voltage VFB Rising 122 mV PG Hysteresis 5 mV PG Leakage VPG = 5V 0.1 1 μA PG Sink Current VPG = 3V ● 100 600 μA
Note 1:
Stresses beyond those listed under Absolute Maximum Ratings guaranteed over the –40°C to 125°C temperature range. The LT3481H may cause permanent damage to the device. Exposure to any Absolute specifi cations are guaranteed over the –40°C to 150°C operating Maximum Rating condition for extended periods may affect device temperature range. High junction temperatures degrade operating reliability and lifetime. lifetimes. Operating lifetime is derated at junction temperatures greater
Note 2:
The LT3481E is guaranteed to meet performance specifi cations than 125°C. from 0°C to 85°C. Specifi cations over the –40°C to 85°C operating
Note 3:
Bias current fl ows into the FB pin. temperature range are assured by design, characterization and correlation
Note 4:
This is the minimum voltage across the boost capacitor needed with statistical process controls. The LT3481I specifi cations are to guarantee full saturation of the switch. 3481fc 3
