Datasheet LTC3548-2 (Analog Devices) - 2
DescriptionDual Synchronous, Fixed/Adjustable Output, 2.25MHz Step-Down DC/DC Regulator
Pages / Page16 / 2 — ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Note 1). ORDER INFORMATION. …
File Format / SizePDF / 418 Kb
ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Note 1). ORDER INFORMATION. LEAD FREE FINISH. TAPE AND REEL. PART MARKING
ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION (Note 1) ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING
LTC3548-2
TOP VIEW VIN Voltages ...– 0.3V to 6V VOUT1, VFB2 Voltages .. –0.3V to VIN + 0.3V V 1 10 V OUT1 FB2 RUN1, RUN2 Voltages ...–0.3V to V RUN1 2 9 RUN2 IN V 3 11 8 POR MODE/SYNC Voltage .. –0.3V to V IN IN + 0.3V SW1 4 7 SW2 SW1, SW2 Voltages ... –0.3V to VIN + 0.3V GND 5 6 MODE/ POR Voltage ... –0.3V to 6V SYNC Ambient Operating Temperature Range DD PACKAGE 10-LEAD (3mm × 3mm) PLASTIC DFN (Note 2) ..– 40°C to 85°C TJMAX = 125°C, θJA = 40°C/W, θJC = 3°C/W (4-LAYER BOARD) EXPOSED PAD (PIN 11) IS GND, MUST BE SOLDERED TO PCB GND Junction Temperature (Note 5) ... 125°C Storage Temperature Range ...– 65°C to 125°C
ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING PACKAGE DESCRIPTION TEMPERATURE RANGE
LTC3548EDD-2#PBF LTC3548EDD-2#TRPBF LCDK 10-Lead (3mm × 3mm) Plastic DFN –40°C to 85°C Consult LTC Marketing for parts specifi ed with wider operating temperature ranges. Consult LTC Marketing for information on non-standard lead based fi nish parts. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifi cations, go to: http://www.linear.com/tapeandreel/
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. VIN = 3.6V, unless otherwise specifi ed. (Note 2) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VIN Operating Voltage Range l 2.5 5.5 V IFB2 Feedback Pin Input Current l 30 nA VFB2 Feedback Voltage of Channel 2 (Note 3) 0°C ≤ TA ≤ 85°C 0.588 0.6 0.612 V –40°C ≤ TA ≤ 85°C l 0.585 0.6 0.612 V VOUT1 Output Voltage of Channel 1 (Note 3) 0°C ≤ TA ≤ 85°C 1.764 1.8 1.836 V –40°C ≤ TA ≤ 85°C l 1.755 1.8 1.836 V ΔVLINEREG Reference Voltage Line Regulation VIN = 2.5V to 5.5V (Note 3) 0.3 0.5 %/V ΔVLOADREG Output Voltage Load Regulation (Note 3) 0.5 % IS Input DC Supply Current (Note 4) Active Mode VOUT1 = 1.5V, VFB2 = 0.5V 700 950 μA Sleep Mode VOUT1 = 1.9V, VFB2 = 0.63V, MODE/SYNC = 3.6V 40 60 μA Shutdown RUN = 0V, VIN = 5.5V, MODE/SYNC = 0V 0.1 1 μA fOSC Oscillator Frequency VOUT1 = 1.8V, VFB2 = 0.6V l 1.8 2.25 2.7 MHz fSYNC Synchronization Frequency 2.25 MHz ILIM Peak Switch Current Limit Channel 1 VIN = 3V, Duty Cycle <35% 0.95 1.2 1.6 A Peak Switch Current Limit Channel 2 VIN = 3V, VFB2 = 0.5V, Duty Cycle <35% 0.6 0.7 0.9 A RDS(ON) Top Switch On-Resistance (Note 6) 0.35 0.45 Ω Bottom Switch On-Resistance (Note 6) 0.30 0.45 Ω ISW(LKG) Switch Leakage Current VIN = 5V, VRUN = 0V, VFB2 = 0V, VOUT1 = 0V 0.01 1 μA 35482fb 2
