Datasheet LTC1877 (Analog Devices) - 5
Description | High Efficiency Monolithic Synchronous Step-Down Regulator |
Pages / Page | 18 / 5 — TYPICAL PERFORMANCE CHARACTERISTICS. Switch Leakage vs Temperature. … |
File Format / Size | PDF / 246 Kb |
TYPICAL PERFORMANCE CHARACTERISTICS. Switch Leakage vs Temperature. Switch Leakage vs Input Voltage. Burst Mode Operation
LTC1877
TYPICAL PERFORMANCE CHARACTERISTICS Switch Leakage vs Temperature Switch Leakage vs Input Voltage Burst Mode Operation
1400 16 VIN = 10V RUN = 0V RUN = 0V 1200 14 SW 12 5V/DIV 1000 MAIN SWITCH 10 800 VOUT SYNCHRONOUS 20mV/DIV 8 SWITCH AC COUPLED 600 6 400 SWITCH LEAKAGE (nA) SYNCHRONOUS SWITCH LEAKAGE (nA) 4 I SWITCH L 200mA/DIV 200 2 MAIN SWITCH 0 0 –50 –25 0 25 50 75 100 125 0 2 4 6 8 10 1877 G14 10μs/DIV TEMPERATURE (°C) INPUT VOLTAGE (V) VIN = 5V L = 10μH VOUT = 1.5V COUT = 47μF 1877 G12 1877 G13 CIN = 10μF ILOAD = 50mA
Start-Up from Shutdown Load Step Response
RUN VOUT 5V/DIV 50mV/DIV AC COUPLED VOUT 1V/DIV IL 500mA/DIV IL 500mA/DIV ITH 1V/DIV 1877 G15 50μs/DIV 1877 G16 40μs/DIV VIN = 5V CIN = 10μF VIN = 5V CIN = 10μF VOUT = 1.5V COUT = 47μF VOUT = 1.5V COUT = 47μF L = 10μH ILOAD = 500mA L = 10μH ILOAD = 50mA TO 500mA PULSE-SKIPPING MODE
Load Step Response Load Step Response
VOUT VOUT 50mV/DIV 50mV/DIV AC COUPLED AC COUPLED IL 10M 10 s/DIV M IL 500mA/DIV 500mA/DIV ITH ITH 1V/DIV 1V/DIV 1877 G17 40μs/DIV 1877 G18 20μs/DIV VIN = 5V CIN = 10μF VIN = 5V CIN = 10μF VOUT = 1.5V COUT = 47μF VOUT = 1.5V COUT = 47μF L = 10μH ILOAD = 50mA TO 500mA L = 10μH ILOAD = 200mA TO 500mA Burst Mode OPERATION PULSE-SKIPPING MODE 1877fb 5
