Datasheet LTC3773 (Analog Devices) - 3
Description | Triple Output Synchronous 3-Phase DC/DC Controller with Up/Down Tracking |
Pages / Page | 32 / 3 — ELECTRICAL CHARACTERISTICS. (Note 3) The. denotes the specifi cations … |
File Format / Size | PDF / 485 Kb |
ELECTRICAL CHARACTERISTICS. (Note 3) The. denotes the specifi cations which apply over the full
LTC3773
ELECTRICAL CHARACTERISTICS (Note 3) The
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. VCC = VDR = VBOOST = VSDB = 5V, unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS Main Control Loop
VFB Feedback Voltage VITH = 1.2V, 0°C ≤ T ≤ 85°C (Note 4) 0.594 0.600 0.606 V ● 0.591 0.600 0.609 V IVFB Feedback Pin Input Current 0 ≤ VFB ≤ 1V –15 –100 nA V – SENSEMAX Maximum Current Sense Threshold VFB = 0.55V, VTRACK = 1V, VSENSE = 2.5V 65 75 85 mV ● 60 75 90 mV VFBLOADREG Feedback Voltage Load Regulation Measured in Servo Loop (Note 4) ΔITH Voltage = 1.2V to 0.7V ● 0.15 0.5 % ΔITH Voltage = 1.2V to 2V ● –0.2 –0.5 % VFBLNREG Feedback Voltage Line Regulation VCC = 4.5V to 6V 0.01 %/V gm Transconductance Amplifi er gm VITH = 1.2V, Sink/Source 25μA (Note 4) ● 2.3 2.7 3.2 mmho fu Transconductance Amplifi er GBW VITH = 1.2V (Note 5) 3 MHz AERR Transconductance Amplifi er DC Gain VITH = 0.8V to 1.6V ● 50 56 dB VUVR VCC Undervoltage Reset VCC Ramping Positive 3.7 4.1 4.4 V Undervoltage Hysteresis 0.16 V VCC VCC Supply Voltage ● 4.5 5 6 V IVCC VCC Supply Current Normal Mode VCC = 5V 2.8 4 mA Shutdown VSDB = 0V 20 30 μA IVDR VDR Supply Current Normal Mode VDR = 5V (Note 6) 5 mA Shutdown VSDB = 0V 1 μA IBOOST VBOOST Supply Current Normal Mode VBOOST = 5V, VSW = 0V (Note 6) 1 mA Shutdown VSDB = 0V 1 μA ISDB SDB Source Current –1.5 μA SDB1, SDB2, SDB3 Source Content –0.5 μA VSDB SDB Power Up Threshold Ramping Positive ● 0.4 V SDB1 Pin CH1 ON Threshold ● 1.14 1.2 1.26 V SDB2 Pin CH2 ON Threshold ● 1.71 1.8 1.89 V SDB3 Pin CH3 ON Threshold ● 2.3 2.4 2.5 V Channel On Threshold Hysteresis –10 % I + – SENSE SENSE Pins Source Current VSENSE , VSENSE = 1.2V, Current at Each Pin –13 –20 μA DFMAX Maximum Duty Factor PLLFLTR Floats, In Dropout 97 98.5 % TG RUP TG Driver Pull-Up On-Resistance TG High, IOUT = 100mA (Note 7) 2.2 Ω TG RDOWN TG Driver Pull-Down On-Resistance TG Low, IOUT = 100mA (Note 7) 1.8 Ω BG RUP BG Driver Pull-Up On-Resistance BG High, IOUT = 100mA (Note 7) 2.4 Ω BG RDOWN BG Driver Pull-Down On-Resistance BG Low, IOUT = 100mA (Note 7) 0.9 Ω TG/BG t1D Top Gate OFF to Bottom Gate ON Delay All Controllers 50 ns Synchronous Switch-On Delay Time BG/TG t2D Bottom Gate OFF to Top Gate ON Delay All Controllers 50 ns Top Switch-On Delay Time tON(MIN) Minimum On-Time Tested with a Square Wave (Note 8) 130 ns
Tracking
ITRACK TRACK Pin Pull-Up Current VSDB = 5V, VTRACK = 0V –1 μA VFBTRACK VFB Voltage During Tracking VTRACK = 0.2V, VITH = 1.2V (Note 4) 180 200 220 mV VTRACK = 0.4V, VITH = 1.2V (Note 4) 380 400 420 mV 3773fb 3
