Datasheet LTC3707-SYNC (Analog Devices) - 4
DescriptionHigh Efficiency, 2-Phase Synchronous Step-Down Switching Regulator
Pages / Page32 / 4 — ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply …
File Format / SizePDF / 404 Kb
ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the full operating
ELECTRICAL CHARACTERISTICS The denotes the specifi cations which apply over the full operating
LTC3707-SYNC
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. VIN = 15V, VRUN/SS1, 2 = 5V unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
IPLLFLTR Phase Detector Output Current Sinking Capability fPLLIN < fOSC –15 μA Sourcing Capability fPLLIN > fOSC 15 μA
3.3V Linear Regulator
V3.3OUT 3.3V Regulator Output Voltage No Load l 3.20 3.35 3.45 V V3.3IL 3.3V Regulator Load Regulation I3.3 = 0 to 10mA 0.5 2 % V3.3VL 3.3V Regulator Line Regulation 6V < VIN < 30V 0.05 0.2 %
PGOOD Output
VPGL PGOOD Voltage Low IPGOOD = 2mA 0.1 0.3 V IPGOOD PGOOD Leakage Current VPGOOD = 5V ±1 μA VPG PGOOD Trip Level, Either Controller VOSENSE with Respect to Set Output Voltage VOSENSE Ramping Negative –6 –7.5 –9.5 % VOSENSE Ramping Positive 6 7.5 9.5 %
Note 1:
Note 4:
The IC is tested in a feedback loop that servos VITH1, 2 to a may cause permanent damage to the device. Exposure to any Absolute specifi ed voltage and measures the resultant VOSENSE1, 2. Maximum Rating condition for extended periods may affect device
Note 5:
Dynamic supply current is higher due to the gate charge being reliability and lifetime. delivered at the switching frequency. See Applications Information.
Note 2:
The LTC3707E-SYNC is guaranteed to meet performance
Note 6:
Rise and fall times are measured using 10% and 90% levels. specifi cation from 0°C to 85°C. Specifi cations over the –40°C to 85°C Delay times are measured using 50% levels. operating temperature range are assured by design, characterization
Note 7:
The minimum on-time condition is specifi ed for an inductor and correlation with statistical process controls. The LTC3707I-SYNC peak-to-peak ripple current ≥40% of IMAX (see minimum on-time is guaranteed to meet performance specifi cations over the full –40°C considerations in the Applications Information section). to 85°C operating temperature range.
Note 3:
TJ is calculated from the ambient temperature TA and power dissipation PD according to the following formulas: LTC3707-SYNC: TJ = TA + (PD • 95 °C/W)
TYPICAL PERFORMANCE CHARACTERISTICS Effi ciency vs Output Current Effi ciency vs Output Current Effi ciency vs Input Voltage and Mode (Figure 13) (Figure 13) (Figure 13)
100 100 100 Burst Mode V 90 IN = 7V OPERATION 80 90 90 70 VIN = 10V FORCED VIN = 15V 60 CONTINUOUS 80 80 MODE 50 VIN = 20V 40 CONSTANT 70 70 EFFICIENCY (%) EFFICIENCY (%) EFFICIENCY (%) 30 FREQUENCY (BURST DISABLE) 20 60 60 10 V V IN = 15V OUT = 5V V I OUT = 5V VOUT = 5V OUT = 3A 0 50 50 0.001 0.01 0.1 1 10 0.001 0.01 0.1 1 10 5 15 25 35 OUTPUT CURRENT (A) OUTPUT CURRENT (A) INPUT VOLTAGE (V) 3707 G01 3707 G02 3707 G03 3707sfa 4
