Datasheet LTC3701 (Analog Devices) - 3
Description2-Phase, Low Input Voltage, Dual Step-Down DC/DC Controller
Pages / Page20 / 3 — ELECTRICAL CHARACTERISTICS The. denotes specifications which apply over …
File Format / SizePDF / 261 Kb
ELECTRICAL CHARACTERISTICS The. denotes specifications which apply over the full operating
ELECTRICAL CHARACTERISTICS The denotes specifications which apply over the full operating
LTC3701
denotes specifications which apply over the full operating temperature range, otherwise specifications are TA = 25
C. VIN = 4.2V unless otherwise noted. PARAMETER CONDITIONS MIN TYP MAX UNITS Oscillator and Phase-Locked Loop
Oscillator Frequency VPLLLPF = 1.2V or Floating 500 550 600 kHz VPLLLPF = 0V 230 280 320 kHz VPLLLPF ≥ 2.4V 690 775 890 kHz Phase Detector Output Current Sinking fEXTCLK/MODE < fOSC – 5 µA Sourcing fEXTCLK/MODE > fOSC 5 µA
PGOOD Output
PGOOD Voltage Low IPGOOD = 500µA 70 150 mV PGOOD Trip Level VFB with Respect to Set Output Voltage VFB Ramping Positive –15 –8 –2.5 % VFB Ramping Negative 2.5 8 15 %
Note 1:
Note 4:
Dynamic supply current is higher due to gate charge being of a device may be impaired. delivered at the switching frequency.
Note 2:
The LTC3701E is guaranteed to meet performance specifications
Note 5:
The LTC3701 is tested in a feedback loop that servos ITH/RUN to a from 0°C to 70°C. Specifications over the –40°C to 85°C operating specified voltage and measures the resultant VFB voltage. temperature range are assured by design, characterization and correlation
Note 6:
Peak current sense voltage is reduced dependent on duty cycle to with statistical process controls. a percentage of value as given in Figure 2.
Note 3:
TJ is calculated from the ambient temperature TA and power dissipation PD according to the following formula: TJ = TA + (PD • θJA°C/W)
W U TYPICAL PERFOR A CE CHARACTERISTICS Shutdown Threshold Oscillator Frequency Reference Voltage vs Temperature vs Temperature vs Temperature
0.810 0.50 1000 VIN = 4.2V V 0.48 VIN = 4.2V IN = 4.2V 900 0.805 0.46 PLLLPF = 2.4V 0.44 800 0.42 0.800 700 0.40 0.38 600 PLLLPF = FLOAT 0.795 0.36 500 0.34 0.790 0.32 400 /RUN VOLTAGE (V) 0.30 FREQUENCY (kHz) PLLLPF = 0V 0.785 I TH 300 REFERENCE VOLTAGE (V) 0.28 0.26 200 0.780 0.24 100 0.22 0.775 0.20 0 –60 –40 –20 0 20 40 60 80 100 –60 –40 –20 0 20 40 60 80 100 –60 –40 –20 0 20 40 60 80 100 TEMPERATURE (°C) TEMPERATURE (°C) TEMPERATURE (°C) 3701 G01 3701 G02 3701 G03 3701fa 3
