Datasheet ACS711 (Allegro) - 9
Manufacturer | Allegro |
Description | Hall Effect Linear Current Sensor with Overcurrent Fault Output for <100 V Isolation Applications |
Pages / Page | 18 / 9 — Hall-Effect Linear Current Sensor with. ACS711. Overcurrent Fault Output … |
File Format / Size | PDF / 1.1 Mb |
Hall-Effect Linear Current Sensor with. ACS711. Overcurrent Fault Output for < 100 V Isolation Applications
Hall-Effect Linear Current Sensor with ACS711 Overcurrent Fault Output for < 100 V Isolation Applications Characteristic Performance Data
Data taken using the ACS711KEX-31AB, VCC = 3.3 V
QVO versus Ambient Temperature QVO Error versus Ambient Temperature 1700 50 1690 40 1680 30 1670 20 V) V) 1660 10 (m 1650 E 0 1640 QVO(m V O -10 1630 -20 1620 -30 1610 -40 1600 -50 -60 -40 -20 0 20 40 60 80 100 120 140 -60 -40 -20 0 20 40 60 80 100 120 140 T (°C) T (°C) A A Sensitivity versus Ambient Temperature Total Error versus Ambient Temperature 50 15 49 ) 48 10 47 V/A ) 5 46 (% 45 0 44 ETOT sitivity (m 43 -5 Sen 42 -10 41 40 -15 -60 -40 -20 0 20 40 60 80 100 120 140 -60 -40 -20 0 20 40 60 80 100 120 140 T (°C) T (°C) A A Symmetry versus Ambient Temperature Nonlinearity versus Ambient Temperature 101 1 100.8 0.8 100.6 0.6 ) 100.4 0.4 ) 100.2 0.2 M(% (% 100 0 ESY 99.8 ELIN -0.2 99.6 -0.4 99.4 -0.6 99.2 -0.8 99 -1 -60 -40 -20 0 20 40 60 80 100 120 140 -60 -40 -20 0 20 40 60 80 100 120 140 T (°C) T (°C) A A
Typical Maximum Limit Mean Typical Minimum Limit Allegro MicroSystems, LLC 9 115 Northeast Cutoff Worcester, Massachusetts 01615-0036 U.S.A. 1.508.853.5000; www.allegromicro.com
