Datasheet AK4376A (Asahi Kasei Microdevices) - 2
Manufacturer | Asahi Kasei Microdevices |
Description | Low-Power Advanced 32-bit DAC with HP |
Pages / Page | 68 / 2 — [AK4376A] 3. Table of Contents. 5. General Description . 1. Features . 1. … |
Revision | 00 |
[AK4376A] 3. Table of Contents. 5. General Description . 1. Features . 1. Table of Contents . 2
![[AK4376A] 3 Table of Contents 5 General Description 1 Features 1 Table of Contents 2](https://www.rlocman.ru/datasheet/img.php?di=152089&p=1)
1.
2.
3.
4.
Features . 1
Block Diagram and Functions . 4
Pin Configurations and Functions . 5
■ Pin Configurations . 5
■ Pin Functions . 6
■ Handing of Unused Pins . 8
6.
Absolute Maximum Ratings . 9
7.
Recommended Operating Conditions . 9
8.
Electrical Characteristics. 10
■ Analog Characteristics . 10
■ PLL Characteristics . 13
■ Charge Pump & LDO Circuit Power-up Time . 13
■ Power Supply Current . 13
■ Power Consumptions for Each Operation Mode . 14
■ DAC Sharp Roll-Off Filter (fs = 44.1 kHz) . 15
■ DAC Sharp Roll-Off Filter (fs = 96 kHz) . 15
■ DAC Sharp Roll-Off Filter (fs = 192 kHz) . 16
■ DAC Slow Roll-Off Filter (fs = 44.1 kHz) . 17
■ DAC Slow Roll-Off Filter (fs = 96 kHz) . 17
■ DAC Slow Roll-Off Filter (fs = 192 kHz) . 18
■ DAC Short Delay Sharp Roll-Off Filter (fs = 44.1 kHz) . 19
■ DAC Short Delay Sharp Roll-Off Filter (fs = 96 kHz) . 19
■ DAC Short Delay Sharp Roll-Off Filter (fs = 192 kHz) . 20
■ DAC Short Delay Slow Roll-Off Filter (fs = 44.1 kHz). 21
■ DAC Short Delay Slow Roll-Off Filter (fs = 96 kHz). 21
■ DAC Short Delay Slow Roll-Off Filter (fs = 192 kHz). 22
■ DC Characteristics . 23
■ Switching Characteristics . 24
■ Timing Diagram (System Clock) . 26
■ Timing Diagram (Serial Audio I/F) . 27
■ Timing Diagram (I2C Interface) . 28
■ Timing Diagram (Reset) . 28
9.
Functional Description . 29
■ System Clock . 29
■ PLL . 33
■ Input Clock Select Function . 33
■ DACMCLK Generating Divider Setting . 36
■ Crystal Oscillator . 36
■ DAC Digital Filter. 37
■ Digital Mixing . 37
■ Digital Volume . 38
■ Headphone Amplifier Output (HPL/HPR pins) . 39
■ Charge Pump & LDO Circuits . 47
■ Serial Audio Interface . 48
■ Power-up & Operation Mode . 49
■ Serial Control Interface (I2C-bus) . 50
■ Control Sequence . 54
■ Register Map . 56
016014206-E-00 2016/11
-2-
