Datasheet LTM2889 (Analog Devices) - 4
DescriptionIsolated CAN FD µModule Transceiver and Power
Pages / Page30 / 4 — ELECTRICAL. CHARACTERISTICS The. denotes specifications which apply over …
ELECTRICAL. CHARACTERISTICS The. denotes specifications which apply over the full operating
ELECTRICAL CHARACTERISTICS The denotes specifications which apply over the full operating
LTM2889
denotes specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. Unless otherwise noted, the following conditions apply: PVCC = VCC = 3.3V for the LTM2889-3, PVCC = VCC = 5V for the LTM2889-5, VL = 3.3V, GND = GND2 = S = RE = RS = 0V, ON = VL. Figure 10 applies for VCC2 = 3.3V; otherwise ADJ is floating. Figure 1 applies with RL = 60Ω and dominant mode measurements are taken prior to TXD dominant timeout (t < tTOTXD). (Note 2) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS Control Inputs S, ON, RE:
VIH HIGH-level Input Voltage VL ≥ 2.35V l 0.7 • VL VL + 0.3 V 1.62V ≤ VL < 2.35V l 0.75 • VL VL + 0.3 V VIL LOW-level Input Voltage VL ≥ 2.35V l –0.3 0.3 • VL V 1.62V ≤ VL < 2.35V l –0.3 0.25 • VL V IIH HIGH-level Input Current ON = S = RE = VL l 11 25 µA IIL LOW-level Input Current ON = S = RE = 0V l ±1 µA
CAN Transmit Data Input Pin TXD
VIH HIGH-level Input Voltage VL ≥ 2.35V l 0.7 • VL VL + 0.3 V 1.62V ≤ VL < 2.35V l 0.75 • VL VL + 0.3 V VIL LOW-level Input Voltage VL ≥ 2.35V l –0.3 0.3 • VL V 1.62V ≤ VL < 2.35V l –0.3 0.25 • VL V IIH HIGH-level Input Current TXD = VL l ±5 µA IIL LOW-level Input Current TXD = 0V l –50 –2 µA CIN Input Capacitance (Note 6) 5 pF
CAN Receive Data Output Pin RXD
IOH HIGH-level Output Current RXD = VL – 0.4V 3V ≤ VL ≤ 5.5V l –4 mA 1.62V ≤ VL < 3V l –1 mA IOL LOW-level Output Current RXD = 0.4V, Bus 3V ≤ VL ≤ 5.5V l 4 mA Dominant 1.62V ≤ VL < 3V l 1 mA
Bus Driver Pins CANH, CANL
VO(D) Bus Output Voltage (Dominant) CANH TXD = 0V, t< tTOTXD VCC2 = 5V l 2.75 3.6 4.5 V to GND2 VCC2 = 3.3V l 2.15 2.9 3.3 V CANL TXD = 0V, t< tTOTXD VCC2 = 5V l 0.5 1.4 2.25 V VCC2 = 3.3V l 0.5 0.9 1.65 V VO(R) Bus Output Voltage (Recessive) to GND2 VCC2 = 5V, No Load (Figure 1) l 2 2.5 3 V VCC2 = 3.3V, No Load (Figure 1) l 1.45 1.95 2.45 V VOD(D) Differential Output Voltage (Dominant) RL = 50Ω to 65Ω (Figure 1) l 1.5 2.2 3 V VOD(R) Differential Output Voltage (Recessive) No Load (Figure 1) l –500 0 50 mV VOC(D) Common Mode Output Voltage (Dominant) VCC2 = 5V, (Figure 1) l 2 2.5 3 V to GND2 VCC2 = 3.3V, (Figure 1) l 1.45 1.95 2.45 V IOS(D) Bus Output Short-Circuit Current CANH CANH = 0V to GND2 l –100 –75 mA (Dominant) CANH CANH = ±60V to GND2 l –100 3 mA CANL CANL = 5V to GND2 l 75 110 mA CANL CANL = ±60V to GND2 l –3 100 mA 2889fa 4 For more information www.linear.com/LTM2889
