Datasheet LTM2889 (Analog Devices) - 6
DescriptionIsolated CAN FD µModule Transceiver and Power
Pages / Page30 / 6 — SWITCHING. CHARACTERISTICS The. denotes specifications which apply over …
SWITCHING. CHARACTERISTICS The. denotes specifications which apply over the full operating
SWITCHING CHARACTERISTICS The denotes specifications which apply over the full operating
LTM2889
denotes specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. Unless otherwise noted, the following conditions apply: PVCC = VCC = 3.3V for the LTM2883-3, PVCC = VCC = 5V for the LTM2883-5, VL = 3.3V, GND = GND2 = S = RE = RS = 0V, ON = VL. Figure 2 applies with RL = 60Ω, CL = 100pF, RSL = 0Ω. Figure 10 applies for VCC2 = 3.3V; otherwise ADJ is floating. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS Transceiver Timing
fMAX Maximum Data Rate l 4 Mbps tPTXBD TXD to Bus Dominant Propagation Delay (Figure 3) VCC2 = 3.3V l 55 105 165 ns VCC2 = 5V l 50 100 150 ns tPTXBR TXD to Bus Recessive Propagation Delay (Figure 3) VCC2 = 3.3V l 100 145 205 ns VCC2 = 5V l 80 115 155 ns tPTXBDS TXD to Bus Dominant Propagation Delay, RSL = 200k VCC2 = 3.3V l 200 565 1255 ns Slow Slew (Figure 3) VCC2 = 5V l 220 585 1225 ns tPTXBRS TXD to Bus Recessive Propagation Delay, Slow RSL = 200k VCC2 = 3.3V l 420 985 2035 ns Slew (Figure 3) VCC2 = 5V l 490 1065 2245 ns tPBDRX Bus Dominant to RXD Propagation Delay (Figure 3) l 40 65 100 ns tPBRRX Bus Recessive to RXD Propagation Delay (Figure 3) l 45 70 115 ns tPTXRXD TXD to RXD Dominant Propagation Delay (Figure 3) VCC2 = 3.3V l 120 170 240 ns VCC2 = 5V l 110 165 225 ns tPTXRXR TXD to RXD Recessive Propagation Delay (Figure 3) VCC2 = 3.3V l 160 215 275 ns VCC2 = 5V l 140 185 245 ns tPTXRXDS TXD to RXD Dominant Propagation Delay, RSL = 200k VCC2 = 3.3V l 210 550 1170 ns Slow Slew (Figure 3) VCC2 = 5V l 240 580 1150 ns tPTXRXRS TXD to RXD Recessive Propagation Delay, RSL = 200k VCC2 = 3.3V l 450 990 1960 ns Slow Slew (Figure 3) VCC2 = 5V l 500 1070 2150 ns tTOTXD TXD Timeout Time (Figure 4) l 0.5 2 4 ms tBIT(RXD),2M Receiver Output Recessive Bit Time, 2Mbps, (Figure 8) VCC2 = 3.3V l 400 455 550 ns Loop Delay Symmetry VCC2 = 5V l 400 475 550 ns tBIT(RXD),4M Receiver Output Recessive Bit Time, 4Mbps (Figure 8) VCC2 = 5V l 200 225 275 ns tZLR Receiver Output Enable Time (Figure 5) l 20 ns tLZR Receiver Output Disable Time (Figure 5) l 30 ns tENRSRX RXD Enable from Shutdown Time (Figure 6) l 40 µs tENRSTX TXD Enable from Shutdown TIme (Figure 7) (Note 5) l 40 µs tSHDNRX Time to Shutdown, Receiver (Figure 6) l 3 µs tSHDNTX Time to Shutdown, Transmitter (Figure 7) l 250 ns
Power Supply Generator
tENPS VCC2 Supply Start-Up Time No load, ON ↑, VCC2 to 4.5V l 2.3 5 ms
Transmitter Drive Symmetry (Common Mode Voltage Fluctuation)
VSYM Driver Symmetry (CANH + CANL – 2VO(R)) RL = 60Ω/Tol. < 1%, CSPLIT = 4.7nF/5%, l ±500 mV (Dynamic Peak Measurement) fTXD = 250kHz, Input Impedance of Oscilloscope: ≤ 20pF/≥1MΩ (Figure 2) 2889fa 6 For more information www.linear.com/LTM2889
