Datasheet LTM8071 (Analog Devices) - 24
Description | 60VIN, 5A Silent Switcher µModule Regulator |
Pages / Page | 24 / 24 — TYPICAL APPLICATION |
File Format / Size | PDF / 1.4 Mb |
TYPICAL APPLICATION
LTM8071
TYPICAL APPLICATION 0.97VOUT from 3.6VIN to 60VIN Step-Down Converter with Spread Spectrum. BIAS Is Tied to an External 3.3V Source
V V LTM8071 IN IN 3.6V TO 60V RUN FB 1µF V V OUT OUT 0.97V 6A 100µF EXT 3.3V BIAS ×2 SYNC GND RT 8071 TA07 110k 400kHz PINS NOT USED IN THIS CIRCUIT: TR/SS, PG, SHARE, AUX
DESIGN RESOURCES SUBJECT DESCRIPTION
µModule Design and Manufacturing Resources Design: Manufacturing: • Selector Guides • Quick Start Guide • Demo Boards and Gerber Files • PCB Design, Assembly and Manufacturing Guidelines • Free Simulation Tools • Package and Board Level Reliability µModule Regulator Products Search 1. Sort table of products by parameters and download the result as a spread sheet. 2. Search using the Quick Power Search parametric table. Digital Power System Management Analog Devices’ family of digital power supply management ICs are highly integrated solutions that offer essential functions, including power supply monitoring, supervision, margining and sequencing, and feature EEPROM for storing user configurations and fault logging.
RELATED PARTS PART NUMBER DESCRIPTION COMMENTS
LTM8050 58V, 2A Step-Down µModule Regulator 3.6V ≤ VIN ≤ 58V, 0.8V ≤ VOUT ≤ 24V, 9mm × 15mm × 4.92mm BGA LTM8073 60V, 3A Step-Down Silent Switcher µModule Regulator 3.4V ≤ VIN ≤ 60V, 0.8V ≤ VOUT ≤ 15V, 6.25mm × 9mm × 3.32mm BGA LTM8064 58V, ±6A CVCC Step-Down µModule Regulator 6V ≤ VIN ≤ 58V, 1.2V ≤ VOUT ≤ 36V, 11.9mm × 16mm × 4.92mm BGA LTM4651 EN55022B Compliant, 58VIN, 24W Inverting-Output 3.6V ≤ VIN ≤ 58V, –26.5V ≤ VOUT ≤ –0.5V, IOUT ≤ 4A, 15mm × 9mm × 5.01mm BGA µModule Regulator LTM4653 EN55022B Compliant, 58VIN, 4A, Step-Down µModule 3.6V ≤ VIN ≤ 58V, –26.5V ≤ VOUT ≤ –0.5V, IOUT ≤ 4A, 15mm × 9mm × 5.01mm BGA Regulator LTM8052 36V, ±5A CVCC Step-Down µModule Regulator 6V ≤ VIN ≤ 36V, 1.2V ≤ VOUT ≤ 24V, 11.25mm × 15mm × 2.82mm LGA, 11.25mm × 15mm × 3.42mm BGA LTM8053 40V, 3.5A Step-Down Silent Switcher µModule 3.4V ≤ VIN ≤ 40V, 0.97V ≤ VOUT ≤ 15V, 6.25mm × 9mm × 3.32mm BGA Regulator LTM4613 EN55022B Compliant, 36V, 8A Step-Down µModule 5V ≤ VIN ≤ 36V, 3.3V ≤ VOUT ≤ 15V, 15mm × 15mm × 4.32mm LGA, Regulator 15mm × 15mm × 4.92mm BGA Rev 0 24 10/18 www.analog.com For more information www.analog.com ANALOG DEVICES, INC. 2018 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Order Information Pin Configuration Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Operation Applications Information Typical Applications Package Description Package Photos Package Description Typical Application Related Parts
