Datasheet LTM4700 (Analog Devices) - 6
DescriptionDual 50A or Single 100A µModule Regulator with Digital Power System Management
Pages / Page126 / 6 — ELECTRICAL CHARACTERISTICS. The. denotes the specifications which apply …
File Format / SizePDF / 2.9 Mb
ELECTRICAL CHARACTERISTICS. The. denotes the specifications which apply over the specified internal
ELECTRICAL CHARACTERISTICS The denotes the specifications which apply over the specified internal
link to page 90 link to page 90 link to page 11 LTM4700
denotes the specifications which apply over the specified internal operating temperature range (Note 2). Specified as each individual output channel (Note 4). TA = 25°C, VIN = 12V, RUNn = 3.3V, FREQUENCY_SWITCH = 350kHz and VOUTn commanded to 1.000V unless otherwise noted. Configured with factory-default EEPROM settings and per Test Circuit 1, unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
tSETTLE Settling Time for Dynamic Load Load: 0A to 12.5A and 12.5A to 0A at 10A/µs, 50 µs Step VOUTn = 1V, VIN = 12V (Note 12) IOUTn(OCL_PK) Output Current Limit, Peak High Cycle-by-Cycle Inductor Peak Current Limit Inception, 60 A Range Utilizing MFR_PWM_MODE[7] = 1, Using ~IOUT = 50A, Page 90 IOUTn(OCL_AVG) Output Current Limit, Time Time-Averaged Output Inductor Current Limit Inception 52A; See IO-RB-ACC Averaged Threshold, Commanded by IOUT_OC_FAULT_LIMITn (Note Specification (Output Current 12) Readback Accuracy) Utilizing MFR_PWM_MODE[7] = 1, Using ~IOUT = 50A, Page 90
Control Section
V – FBCM0 Channel 0 Feedback Input Common VOSNS0 Valid Input Range (Referred to SGND) l –0.1 0.3 V Mode Range V + OSNS0 Valid Input Range (Referred to SGND) l 3.6 V V – FBCM1 Channel 1 Feedback Input Common VOSNS1 Valid Input Range (Referred to GND) l –0.3 0.3 V Mode Range V + OSNS1 Valid Input Range (Referred to SGND) l 3.6 V VOUT-RNGL Full-Scale Command Voltage, VOUTn Commanded to 2.750V, MFR_PWM_MODEn[1] = 1b 2.7 2.8 V Range Low (0.6V to 2.75V, Notes Set Point Accuracy −0.5 −0.5 % 7, 15) Resolution 12 Bits LSB Step Size 0.688 mV R + + + VSNS0 VOSNS0 Impedance to SGND 0.05V ≤ VVOSNS0 – VSGND ≤ 1.8V 50 kΩ R + VSNS1 VOSNS1 Impedance to SGND 0.05V ≤ VVOSNS1 – VSGND ≤ 1.8V 50 kΩ tON(MIN) Minimum On-Time (Note 8 ) 60 ns
Analog OV/UV (Overvoltage/Undervoltage) Output Voltage Supervisor Comparators (VOUT_OV/UV_FAULT_LIMIT and VOUT_OV/UV_WARN_LIMIT Monitors)
NOV/UV_COMP Resolution, Output Voltage (Notes 14, 15) 9 Bits Supervisors VOV-RNG Output OV Comparator Threshold (Notes 14, 15) Detection Range High Range Scale, MFR_PWM_MODEn[1] = 0b 1 3.6 V Low Range Scale, MFR_PWM_MODEn[1] = 1b 0.5 2.7 V VOUSTP Output OV and UV Comparator (Note 15) Threshold Programming LSB Step High Range Scale, MFR_PWM_MODEn[1] = 0b 11.2 mV Size Low Range Scale, MFR_PWM_MODEn[1] = 1b 5.6 mV VOUT-RNGH Full-Scale Command Voltage, VOUTn Commanded to 3.6V, MFR_PWM_MODEn[0] = 1b 3.4 3.6 V Range Low (0.6V to 3.6V, Notes Set Point Accuracy –0.5 –0.5 % 7, 15) Resolution 12 Bits LSB Step Size 1.375 mV gm0,1 Resolution COMP0,1 = 1.35V, MFR_PWM_CONFIG[7:5] = 0 to 7 3 Bits Error Amplifier gm(MAX) 5.76 mmho Error Amplifier gm(MIN) 1 mmho LSB Step Size 0.68 mmho RCOMP0,1 Resolution MFR_PWM_CONFIG[4:0] = 0 to 31 (See Figure 1, Note 5 Bits Compensation Resistor RTH(MAX) Section) 62 kΩ Compensation Resistor RTH(MIN) 0 kΩ V + – OV-ACC-0,1 Output OV Comparator Threshold 1V ≤ VVOSNS0 – VVOSNS0 ≤ 1.8V, MFR_PWM_MODE0[1] = 1b l ±1.5 % Accuracy Channel 0 and 1 0.5V ≤ V + – VOSNS0 – VVOSNS0 < 1V, MFR_PWM_MODE0[1] = 1b l ±30 mV (See Note 14) 1V ≤ V + – VOSNS1 – VVOSNS1 ≤ 1.8V, MFR_PWM_MODE1[1] = 1b l ±1.5 % 0.5V ≤ V + – VOSNS1 – VVOSNS1 < 1V, MFR_PWM_MODE1[1] = 1b l ±30 mV VUV-RNG Output UV Comparator Threshold High Range Scale, MFR_PWM_MODEn[1] = 0b 1 3.6 V Detection Range (Note 15) Low Range Scale, MFR_PWM_MODEn[1] = 1b 0.5 2.7 V Rev 0 6 For more information www.analog.com Document Outline Features Applications Typical Application Description Table of Contents Absolute Maximum Ratings Order Information Pin Configuration Electrical Characteristics Typical Performance Characteristics Pin Functions Simplified Block Diagram Decoupling Requirements Functional Diagram Test Circuits Operation PMBus Command Summary Applications Information Applications Information-Derating Curves Typical Applications PMBus Command Details Package Description Typical Applications Package Photograph Related Parts Features Applications Typical Application Description Table of Contents Absolute Maximum Ratings Order Information Pin Configuration Electrical Characteristics Typical Performance Characteristics Pin Functions Simplified Block Diagram Decoupling Requirements Functional Diagram Test Circuits Operation Power Module Introduction Power Module Overview, Major Features EEPROM with ECC Power-Up and Initialization Soft-Start Time-Based Sequencing Voltage-Based Sequencing Shutdown Light-Load Current Operation Switching Frequency and Phase PWM Loop Compensation Output Voltage Sensing INTVCC and Build-in 5V Bias Converter Output Current Sensing and Sub Milliohm DCR Current Sensing Input Current Sensing PolyPhase Load Sharing External/Internal Temperature Sense RCONFIG (Resistor Configuration) Pins Fault Detection and Handling Status Registers and ALERT Masking Mapping Faults to FAULT Pins Power Good Pins CRC Protection Serial Interface Communication Protection Device Addressing Responses to VOUT and IIN/IOUT Faults Output Overvoltage Fault Response Output Undervoltage Response Peak Output Overcurrent Fault Response Responses to Timing Faults Responses to VIN OV Faults Responses to OT/UT Faults Internal Overtemperature Fault Response External Overtemperature and Undertemperature Fault Response Responses to Input Overcurrent and Output Undercurrent Faults Responses to External Faults Fault Logging Bus Timeout Protection Similarity Between PMBus, SMBus and I2C 2-Wire Interface PMBus Serial Digital Interface Figures 7 to 24 PMBus Protocols PMBus Command Summary PMBus Commands Applications Information VIN to VOUT Step-Down Ratios Input Capacitors Output Capacitors Light Load Current Operation Switching Frequency and Phase Output Current Limit Programming Minimum On-Time Considerations Variable Delay Time, Soft-Start and Output Voltage Ramping Digital Servo Mode Soft Off (Sequenced Off) Undervoltage Lockout Fault Detection and Handling Open-Drain Pins Phase-Locked Loop and Frequency Synchronization Input Current Sense Amplifier Programmable Loop Compensation Checking Transient Response PolyPhase Configuration Connecting The USB to I2C/SMBus/PMBus Controller to the LTM4700 In System LTpowerPlay: An Interactive GUI for Digital Power PMBus Communication and Command Processing Thermal Considerations and Output Current Derating Applications Information-Derating Curves EMI Performance Safety Considerations Layout Checklist/Example Typical Applications PMBus Command Details Addressing and Write Protect General Configuration Commands On/Off/Margin PWM Configuration Voltage Input Voltage and Limits Output Voltage and Limits Output Current and Limits Input Current and Limits Temperature External Temperature Calibration Timing Timing—On Sequence/Ramp Timing—Off Sequence/Ramp Precondition for Restart Fault Response Fault Responses All Faults Fault Responses Input Voltage Fault Responses Output Voltage Fault Responses Output Current Fault Responses IC Temperature Fault Responses External Temperature Fault Sharing Fault Sharing Propagation Fault Sharing Response Scratchpad Identification Fault Warning and Status Telemetry NVM Memory Commands Store/Restore Fault Logging Block Memory Write/Read Package Description Typical Applications Package Photograph Related Parts
