Preliminary Datasheet TCB702FNG (Toshiba) - 9
ManufacturerToshiba
DescriptionMaximum Power 45 W BTL × 4-ch Audio Power IC with Built-in Self-Diagnostics
Pages / Page52 / 9 — Preliminary. 6.3. Slave Address Selectable Function. Table 6.2 Setting …
Preliminary. 6.3. Slave Address Selectable Function. Table 6.2 Setting Slave address and ADSEL resistor
Preliminary 6.3 Slave Address Selectable Function Table 6.2 Setting Slave address and ADSEL resistor
Preliminary
TCB702FNG
In this product, the Slave address can be selected from two or more Slave addresses by connecting ADSEL pin (Pin 27) to GND through a resistor. The Slave address is determined at hardware standby-off. Please set VCC at turning on to 6 V or more. (Refer to Figure 6.3.) The communication should be started after setting Stby pin (Pin 22) to High, and waiting for 1 ms or more.
ADSEL pin pull-down resistor value Setting Slave address and mode Unit Min Typ. Max Slave address 1101100X 0 ― 100 Ω Slave address 1101101X 0.9 1 1.1 kΩ Slave address 1101110X 1.98 2.2 2.42 kΩ Slave address 1101111X 4.23 4.7 5.17 kΩ Standalone control mode (Legacy Mode) 10 ― OPEN kΩ Note: Please connect a pull-down resistor of the ADSEL pin to the adjacent Pre-GND wiring. VCC 6 V Slave address is not determined. Slave address is determined.
Figure 6.3 Slave address determination timing
9 2018-10-23
