Datasheet ADM3053 (Analog Devices) - 5
DescriptionSignal and Power Isolated CAN Transceiver with Integrated Isolated DC-to-DC Converter
Pages / Page18 / 5 — Data Sheet. ADM3053. REGULATORY INFORMATION. Table 3. ADM3053 Approvals …
RevisionE
File Format / SizePDF / 527 Kb
Data Sheet. ADM3053. REGULATORY INFORMATION. Table 3. ADM3053 Approvals Organization Approval Type. Notes
Data Sheet ADM3053 REGULATORY INFORMATION Table 3 ADM3053 Approvals Organization Approval Type Notes
Data Sheet ADM3053 REGULATORY INFORMATION Table 3. ADM3053 Approvals Organization Approval Type Notes
UL Recognized under the Component Recognition In accordance with UL 1577, each ADM3053 is proof tested by applying Program of Underwriters Laboratories, Inc. an insulation test voltage ≥2500 V rms for 1 second. File E214100. VDE Certified according to DIN EN 60747-5-2 (VDE In accordance with VDE 0884-2. File 2471900-4880-0001. 0884 Part 2): 2003-01. CSA Approved under CSA Component Acceptance Basic insulation at 760 V rms (1074 V peak) working voltage. Reinforced Notice 5A. Testing was conducted per CSA insulation at 380 V rms (537 V peak) working voltage. 60950-1-07 and IEC 60950-1, 2nd Edition at Basic insulation at 424 V rms (600 V peak) working voltage. Reinforced 2.5 kV rated voltage. insulation at 300 V rms (424 V peak) working voltage. Testing was conducted per CSA 61010-1-04 File 205078. and IEC 61010-1 2nd Edition at 2.5 kV rated voltage.
INSULATION AND SAFETY-RELATED SPECIFICATIONS Table 4. Parameter Symbol Value Unit Test Conditions/Comments
Rated Dielectric Insulation Voltage 2500 V rms 1-minute duration Minimum External Air Gap (Clearance) L(I01) 7.7 mm Measured from input terminals to output terminals, shortest distance through air Minimum External Tracking (Creepage) L(I02) 7.6 mm Measured from input terminals to output terminals, shortest distance along body Minimum Internal Gap (Internal 0.017 min mm Insulation distance through insulation Clearance) Tracking Resistance (Comparative CTI >400 V DIN IEC 112/VDE 0303-1 Tracking Index) Isolation Group II Material group (DIN VDE 0110: 1989-01, Table 1) Rev. E | Page 5 of 18 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TIMING SPECIFICATIONS SWITCHING CHARACTERISTICS REGULATORY INFORMATION INSULATION AND SAFETY-RELATED SPECIFICATIONS VDE 0884 INSULATION CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS CIRCUIT DESCRIPTION CAN TRANSCEIVER OPERATION SIGNAL ISOLATION POWER ISOLATION TRUTH TABLES THERMAL SHUTDOWN DC CORRECTNESS AND MAGNETIC FIELD IMMUNITY APPLICATIONS INFORMATION PCB LAYOUT EMI CONSIDERATIONS RS PIN INSULATION LIFETIME TYPICAL APPLICATIONS OUTLINE DIMENSIONS ORDERING GUIDE
