Datasheet LT3015 (Analog Devices) - 7
Description | 1.5A, Low Noise, Negative Linear Regulator with Precision Current Limit |
Pages / Page | 26 / 7 — TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C, unless otherwise noted. … |
File Format / Size | PDF / 555 Kb |
TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C, unless otherwise noted. Typical Dropout Voltage. Guaranteed Dropout Voltage
LT3015 Series
TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C, unless otherwise noted. Typical Dropout Voltage Guaranteed Dropout Voltage (DFN/MSOP) (DFN/MSOP) Dropout Voltage (DFN/MSOP)
450 600 500 400 450 500 350 400 TJ ≤ 125°C IL = –1.5A 300 350 400 300 TAGE (mV) 250 TAGE (mV) TAGE (mV) 300 250 200 TJ ≤ 25°C 200 I 150 200 L = –0.5A 150 IL = –0.1A DROPOUT VOL 100 125°C DROPOUT VOL DROPOUT VOL 25°C 100 100 50 –40°C 50 I –55°C = TEST POINTS L = –1mA 0 0 0 0 –0.2 –0.4 –0.6 –0.8 –1 –1.2 –1.4 –1.6 0 –0.2 –0.4 –0.6 –0.8 –1 –1.2 –1.4 –1.6 –75 –50 –25 0 25 50 75 100 125 150 175 OUTPUT CURRENT (A) OUTPUT CURRENT (A) TEMPERATURE (°C) 3015 G01 3015 G02 3015 G03
Typical Dropout Voltage Guaranteed Dropout Voltage (DD-PAK/TO-220) (DD-PAK/TO-220) Dropout Voltage (DD-PAK/TO-220)
600 800 600 700 500 500 600 TJ ≤ 125°C IL = –1.5A 400 400 500 TAGE (mV) TAGE (mV) TAGE (mV) 300 400 300 T I 300 J ≤ 25°C L = –0.5A 200 200 I DROPOUT VOL 125°C DROPOUT VOL 200 DROPOUT VOL L = –0.1A 100 25°C 100 –40°C 100 –55°C = TEST POINTS IL = –1mA 0 0 0 0 –0.2 –0.4 –0.6 –0.8 –1 –1.2 –1.4 –1.6 0 –0.2 –0.4 –0.6 –0.8 –1 –1.2 –1.4 –1.6 –75 –50 –25 0 25 50 75 100 125 150 175 OUTPUT CURRENT (A) OUTPUT CURRENT (A) TEMPERATURE (°C) 3015 G04 3015 G05 3015 G06
Quiescent Current LT3015 ADJ Pin Voltage LT3015-2.5 Output Voltage
–1.4 –1.244 –2.55 LT3015-2.5/-3/-3.3/-5/-12/-15 VIN = –2.3V VIN = –3V –2.54 I –1.2 –1.238 IL = –1mA L = –1mA LT3015 –1.232 –2.53 –1.0 –2.52 –1.226 –0.8 VIN = –6V (LT3015/-2.5/-3/-3.3/-5) TAGE (V) TAGE (V) –2.51 V –1.220 IN = –16V (LT3015-12/-15) –2.50 R –0.6 L = 120kΩ, IL = –10µA (LT3015) –1.214 RL = ∞, IL = –0µA –2.49 (LT3015-2.5/-3/-3.3/-5/-12/-15) –1.208 –0.4 ADJ PIN VOL OUTPUT VOL –2.48 QUIESCENT CURRENT (mA) –1.202 –2.47 –0.2 –1.196 –2.46 VSHDN = 0V 0 –1.192 –2.45 –75 –50 –25 0 25 50 75 100 125 150 175 –75 –50 –25 0 25 50 75 100 125 150 175 –75 –50 –25 0 25 50 75 100 125 150 175 TEMPERATURE (°C) TEMPERATURE (°C) TEMPERATURE (°C) 3015 G07 3015 G09 3015 G08 3015fb 7 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
