Datasheet LT3032 (Analog Devices) - 10
DescriptionDual 150mA Positive/Negative Low Noise Low Dropout Linear Regulator
Pages / Page24 / 10 — TYPICAL PERFORMANCE CHARACTERISTICS. Positive Side GND Pin Current. …
File Format / SizePDF / 410 Kb
TYPICAL PERFORMANCE CHARACTERISTICS. Positive Side GND Pin Current. Negative Side GND Pin Current. vs ILOAD
TYPICAL PERFORMANCE CHARACTERISTICS Positive Side GND Pin Current Negative Side GND Pin Current vs ILOAD
LT3032 Series
TYPICAL PERFORMANCE CHARACTERISTICS Positive Side GND Pin Current Negative Side GND Pin Current vs ILOAD vs ILOAD SHDNP Pin Threshold
5.0 –4.0 1.0 VINP = VOUTP(NOMINAL) + 1V VINN = VOUTN(NOMINAL) – 1V IL = 1mA 4.5 T 0.9 J = 25°C –3.5 4.0 0.8 –3.0 ON 3.5 0.7 3.0 –2.5 TJ = –50°C 0.6 2.5 –2.0 T 0.5 J = 25°C 2.0 –1.5 PIN THRESHOLD (V) 0.4 OFF 1.5 TJ = 125°C 0.3 GND PIN CURRENT (mA) GND PIN CURRENT (mA) –1.0 1.0 SHDNP 0.2 0.5 –0.5 0.1 0 0 0 0 20 40 60 80 100 120 140 160 0 –20 –40 –60 –80 –100 –120 –140 –160 –50 –25 0 25 50 75 100 125 POSITIVE LOAD CURRENT (mA) NEGATIVE LOAD CURRENT (mA) TEMPERATURE (°C) 3032 G14 3032 G13 3032 G15
SHDNN Pin Thresholds SHDNP Pin Input Current SHDNP Pin Input Current
2.5 1.4 1.6 V 2.0 SHDNP = 20V ON 1.2 1.4 1.5 1.2 1.0 1.0 0.5 1.0 0.8 0 0.8 OFF PIN VOLTAGE (V) –0.5 0.6 0.6 –1.0 PIN INPUT CURRENT (µA) PIN INPUT CURRENT (µA) SHDNN 0.4 0.4 –1.5 ON SHDNP 0.2 SHDNP –2.0 0.2 –2.5 0 0 –50 –25 0 25 50 75 100 125 0 1 2 3 4 5 6 7 8 9 10 –50 –25 0 25 50 75 100 125 TEMPERATURE (°C) SHDNP PIN VOLTAGE (V) TEMPERATURE (°C) 3032 G16 3032 G17 3032 G18
SHDNN Pin Input Current SHDNN Pin Input Current ADJP Pin Bias Current
10 12 140 V 8 TJ = 25°C INN = –15V POSITIVE CURRENT 9 POSITIVE CURRENT 120 6 FLOWS INTO THE PIN FLOWS INTO THE PIN 4 6 100 VSHDNN = 15V 2 3 80 0 –2 0 60 PIN INPUT CURRENT (µA) V –4 PIN INPUT CURRENT (µA) SHDNN = –15V –3 40 –6 ADJP PIN BIAS CURRENT (nA) SHDNN SHDNN –6 20 –8 –10 –9 0 –10 –8 –6 –4 –2 0 2 4 6 8 10 –50 –25 0 25 50 75 100 125 –50 –25 0 25 50 75 100 125 SHDNN PIN VOLTAGE (V) TEMPERATURE (°C) TEMPERATURE (°C) 3032 G19 3032 G20 3032 G21 3032ff 10 For more information www.linear.com/LT3032 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Applications Information Package Description Revision History Typical Application Related Parts
