Datasheet 1N5820, 1N5821, 1N5822 (ON Semiconductor) - 6
ManufacturerON Semiconductor
DescriptionAxial Lead Rectifiers
Pages / Page8 / 6 — 1N5820, 1N5821, 1N5822. NOTE 4 - APPROXIMATE THERMAL CIRCUIT MODEL. …
Revision10
File Format / SizePDF / 127 Kb
1N5820, 1N5821, 1N5822. NOTE 4 - APPROXIMATE THERMAL CIRCUIT MODEL. Figure 6. Forward Power Dissipation 1N5820-22
1N5820, 1N5821, 1N5822 NOTE 4 - APPROXIMATE THERMAL CIRCUIT MODEL Figure 6 Forward Power Dissipation 1N5820-22
10
TTS) 7.0 A 5.0 SINE WAVE RqS(A) RqL(A) RqJ(A) RqJ(K) RqL(K) RqS(K) I(FM) TION (W 3.0 p(ResistiveLoad) A I dc TA(A) TA(K) PD 2.0 (AV) TL(A) TC(A) TJ TC(K) TL(K) 1.0 Capacitive SQUARE WAVE 5.010 0.7 Loads 20 0.5 Use of the above model permits junction to lead thermal 0.3 resistance for any mounting configuration to be found. For VERAGE POWER DISSIP 0.2 TJ ≈ 125°C a given total lead length, lowest values occur when one side , A V) of the rectifier is brought as close as possible to the heat sink. 0.1 F(AP 0.1 0.2 0.3 0.5 0.7 1.0 2.0 3.0 5.0 7.0 10 Terms in the model signify: IF(AV), AVERAGE FORWARD CURRENT (AMP) TA = Ambient Temperature TC = Case Temperature
TL = Lead Temperature TJ = Junction Temperature RqS = Thermal Resistance, Heatsink to Ambient RqL = Thermal Resistance, Lead-to-Heatsink RqJ = Thermal Resistance, Junction-to-Case PD = Total Power Dissipation = PF + PR PF = Forward Power Dissipation PR = Reverse Power Dissipation (Subscripts (A) and (K) refer to anode and cathode sides, respectively.) Values for thermal resistance components are: RqL = 42°C/W/in typically and 48°C/W/in maximum RqJ = 10°C/W typically and 16°C/W maximum The maximum lead temperature may be found as follows: TL = TJ(max) n TJL where n TJL RqJL · PD
Mounting Method 1 Mounting Method 3
P.C. Board where available P.C. Board with
NOTE 5 — MOUNTING DATA
copper surface is small. 2-1/2, x 2-1/2, copper surface. Data shown for thermal resistance junction-to-ambient (Rq L L JA) for the mountings shown is to be used as typical guideline values É L = 1/2″ for preliminary engineering, or in case the tie point temperature ÉÉÉÉÉÉÉ É cannot be measured.
TYPICAL VALUES FOR R
ÉÉÉÉÉÉÉ É q
JA IN STILL AIR Lead Length, L (in) Mounting Method 2
É
Mounting Method
É BOARD GROUND
1/8 1/4 1/2 3/4 R
q L L
JA
PLANE 1 50 51 53 55 °C/W ÉÉÉÉÉÉÉÉ 2 58 59 61 63 °C/W ÉÉÉÉÉÉÉÉ VECTOR PUSH-IN 3 28 °C/W TERMINALS T-28
http://onsemi.com 6
