Datasheet HMC988LP3E (Analog Devices) - 8
DescriptionProgrammable Clock Divider & Delay, DC - 4 GHz
Pages / Page22 / 8 — HMC988LP3E. PROGRAMMABLE CLOCK DIVIDER AND DELAY. DC - 4 GHz. Outline …
HMC988LP3E. PROGRAMMABLE CLOCK DIVIDER AND DELAY. DC - 4 GHz. Outline Drawing. Table 4. Package Information
HMC988LP3E PROGRAMMABLE CLOCK DIVIDER AND DELAY DC - 4 GHz Outline Drawing Table 4 Package Information
HMC988LP3E
v04.1014
t M s n - io t u ib r t is k D C lo C notEs: [1] PACkAGE boDY MAtEriAl: loW strEss inJECtion MolDED PlAstiC siliCA AnD siliCon iMPrEGnAtED. [2] lEAD AnD GrounD PADDlE MAtEriAl: CoPPEr AlloY. [3] lEAD AnD GrounD PADDlE PlAtinG: 100% MAttE tin. [4] DiMEnsions ArE in inCHEs [MilliMEtErs]. [5] lEAD sPACinG tolErAnCE is non-CuMulAtiVE. [6] PAD burr lEnGtH sHAll bE 0.15 mm MAX. PAD burr HEiGHt sHAll bE 0.05 mm MAX. [7] PACkAGE WArP sHAll not EXCEED 0.05 mm [8] All GrounD lEADs AnD GrounD PADDlE Must bE solDErED to PCb rF GrounD. [9] rEFEr to HittitE APPliCAtion notE For suGGEstED PCb lAnD PAttErn.
Part number Package body Material lead Finish Msl rating Package Marking [1] HMC988lP3E roHs-compliant low stress injection Molded Plastic 100% matte sn Msl1[2] H988 XXXX [1] 4-Digit lot number XXXX [2] Max peak reflow temperature of 260 °C Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd hone e r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o t niltie n .c e ao t m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com
8
Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
