Datasheet AD5235-EP (Analog Devices) - 5
DescriptionNonvolatile Memory, Dual 1024-Position Digital Potentiometer
Pages / Page14 / 5 — Enhanced Product. AD5235-EP. INTERFACE TIMING AND EEMEM RELIABILITY …
File Format / SizePDF / 540 Kb
Enhanced Product. AD5235-EP. INTERFACE TIMING AND EEMEM RELIABILITY CHARACTERISTICS. Table 2. Parameter. Symbol. Conditions. Min
Enhanced Product AD5235-EP INTERFACE TIMING AND EEMEM RELIABILITY CHARACTERISTICS Table 2 Parameter Symbol Conditions Min
link to page 6 link to page 6 link to page 6
Guaranteed by design and not subject to production test. See the Timing Diagrams section for the location of measured values. All input control voltages are specified with tR = tF = 2.5 ns (10% to 90% of 3 V) and timed from a voltage level of 1.5 V. Switching characteristics are measured using both VDD = 2.7 V and VDD = 5 V.
Table 2. Parameter Symbol Conditions Min Typ1 Max Unit
Clock Cycle Time (tCYC) t1 20 ns CS Setup Time t2 10 ns CLK Shutdown Time to CS Rise t3 1 tCYC Input Clock Pulse Width t4, t5 Clock level high or low 10 ns Data Setup Time t6 From positive CLK transition 5 ns Data Hold Time t7 From positive CLK transition 5 ns CS to SDO-SPI Line Acquire t8 40 ns CS to SDO-SPI Line Release t9 50 ns CLK to SDO Propagation Delay2 t10 RP = 2.2 kΩ, CL < 20 pF 50 ns CLK to SDO Data Hold Time t11 RP = 2.2 kΩ, CL < 20 pF 0 ns CS High Pulse Width3 t12 10 ns CS High to CS High3 t13 4 tCYC RDY Rise to CS Fall t14 0 ns CS Rise to RDY Fall Time t15 0.15 0.3 ms Store EEMEM Time4, 5 t16 Applies to Instructions 0x2, 0x3 15 50 ms Read EEMEM Time4 t16 Applies to Instructions 0x8, 0x9, 0x10 7 30 µs CS Rise to Clock Rise/Fall Setup t17 10 ns Preset Pulse Width (Asynchronous)6 tPRW 50 ns Preset Response Time to Wiper Setting6 tPRESP PR pulsed low to refresh wiper positions 30 µs Power-On EEMEM Restore Time6 tEEMEM 30 µs FLASH/EE MEMORY RELIABILITY Endurance7 TA = 25°C 1 MCycles 100 kCycles Data Retention8 100 Years 1 Typicals represent average readings at 25°C and VDD = 5 V. 2 Propagation delay depends on the value of VDD, RPULL-UP, and CL. 3 Valid for commands that do not activate the RDY pin. 4 The RDY pin is low only for Instruction 2, Instruction 3, Instruction 8, Instruction 9, Instruction 10, and the PR hardware pulse: CMD_8 ~ 20 µs; CMD_9, CMD_10 ~ 7 µs; CMD_2, CMD_3 ~ 15 ms; PR hardware pulse ~ 30 µs. 5 Store EEMEM time depends on the temperature and EEMEM writes cycles. Higher timing is expected at a lower temperature and higher write cycles. 6 Not shown in Figure 2 and Figure 3. 7 Endurance is qualified to 100,000 cycles per JEDEC Standard 22, Method A117 and measured at −40°C, +25°C, and +125°C. 8 Retention lifetime equivalent at junction temperature (TJ) = 85°C per JEDEC Standard 22, Method A117. Retention lifetime based on an activation energy of 1 eV derates with junction temperature in the Flash/EE memory. Rev. B | Page 5 of 14 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS INTERFACE TIMING AND EEMEM RELIABILITY CHARACTERISTICS Timing Diagrams ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
