Datasheet HVLED001B (STMicroelectronics)
DescriptionDS12748: High power factor flyback controller with constant voltage primary-sensing and ultra-low standby consumption
Pages / Page33 / 1 — HVLED001B. High power factor flyback controller with constant voltage. …
Revision1.0
HVLED001B. High power factor flyback controller with constant voltage. primary-sensing and ultra-low standby consumption
Datasheet HVLED001B STMicroelectronics, Revision: 1.0
HVLED001B High power factor flyback controller with constant voltage primary-sensing and ultra-low standby consumption Datasheet - Production data Description
The HVLED001B is an enhanced peak current mode controller able to control mainly high power factor (HPF) flyback or buck-boost. Some other topologies such as buck, boost and SEPIC, can
SSOP10
also be implemented. Primary side regulation and optocoupler control can be applied independently on the chip, both
Features
exploiting precise regulation and very low standby power during no load conditions. Quasi resonant (QR) topology The innovative ST high voltage technology allows Primary side regulation of output voltage direct connection of the HVLED001B to the input Direct optocoupler connection for current loop voltage in order to both start up the device and to regulation with feedback disconnection monitor the input voltage, without the need for detection external components. 800 V high voltage startup Abnormal conditions like open circuit, output High power factor and low THD in universal short-circuit, input over-voltage or under-voltage range and circuit failures like open loop and overcurrent of the main switch are effectively controlled. High efficiency and output stability in wide voltage and current range A smart Auto Recover Timer (ART) function is Extremely low standby power at no load built in to guarantee an automatic application condition recovery, without any loss of reliability. Programmable frequency foldback
Table 1. Device summary
Integrated input voltage detection for high
Order code Package Packaging
power factor capability and protection triggering HVLED001BY Tube SSOP10 Latch-free device guarantee by smart auto- HVLED001BTR Tape and reel reload timer (ART) 0-10 and PWM dimming compatible Remote control pin
Applications
Single-stage LED drivers with high power factor Two-stage LED drivers September 2018 DS12748 Rev 1 1/33 This is information on a product in full production. www.st.com Document Outline Table 1. Device summary 1 Block diagram Figure 1. Block diagram 2 Typical application - HPF flyback Figure 2. Primary side regulated (PSR) application Figure 3. Secondary side regulated (SSR) application 3 Pin settings Figure 4. Pin connection Table 2. Pin description (continued) 4 Electrical data 4.1 Absolute maximum ratings Table 3. Absolute maximum ratings 4.2 Thermal data Table 4. Thermal data 4.3 Recommended operating conditions Table 5. Recommended operating conditions 5 Electrical characteristics Table 6. Electrical characteristics (continued) 6 Typical electrical characteristic 6.1 Parameter graphs Figure 5. ICC vs. Fsw @ VCC = 15V Figure 6. VCC,on and VCC,su vs. Tj Figure 7. Icharge and Icharge,su vs. Tj Figure 8. IFB,src and IFB,snk vs. Tj Figure 9. Vbm, Vbm2 and VOPTO,dis vs. Tj Figure 10. Tbm and Tbm2 vs. Tj Figure 11. VZCD,arm and VZCD,trig vs. Tj Figure 12. VCS,lim vs. Tj Figure 13. VREF,PSR vs. Tj Figure 14. IFB vs. VZCD sample Figure 15. TBLANK,min vs. Tj Figure 16. TBLANK,var vs. Tj 7 Application information 7.1 Operating modes Figure 17. High power factor flyback - Primary side regulated constant output voltage Figure 18. High power factor flyback – Secondary side regulated application 7.1.1 Start-up mode Figure 19. Initial start-up phase 7.1.2 Ramp-up mode 7.1.3 Active mode 7.1.4 Low consumption mode 7.1.5 Stop mode 7.2 Control loop Figure 20. Control loop blocks 7.2.1 Current sense input 7.2.2 Feedback input 7.2.3 Zero current detection Figure 21. TBLANK,var time vs. TOFF voltage Figure 22. TBLANK,var time vs. TOFF voltage 7.2.4 Primary side regulation feature Figure 23. PSR E/A small signal model 7.2.5 Burst mode operation 7.3 Gate driver 7.4 IC supply management 7.4.1 VCC supply management 7.4.2 High voltage startup Table 7. HVSU operating modes 7.5 Auto restart timer (ART) 7.6 Protections 7.6.1 Over current protection (OCP) 7.6.2 Input over voltage protection (I-OVP) 7.6.3 Brownout protection (BO) 7.6.4 Over power protection (OPP) 7.6.5 Output over voltage protection (oOVP) 7.7 Disable and monitor feature 8 Package information 8.1 SSOP10 package outline Figure 24. SSOP10 package mechanical data Table 8. SSOP10 package mechanical data 9 Revision history Table 9. Document history
