Datasheet BCR602 (Infineon) - 4
ManufacturerInfineon
Description60V linear LED controller IC for dimmable LED
Pages / Page15 / 4 — BCR602 hot plug IC with dimming. Pin configuration. Figure 2. Table 2. …
Revision01_01
File Format / SizePDF / 478 Kb
BCR602 hot plug IC with dimming. Pin configuration. Figure 2. Table 2. Pin no. Pin name. Pin type. Function
BCR602 hot plug IC with dimming Pin configuration Figure 2 Table 2 Pin no Pin name Pin type Function
BCR602 hot plug IC with dimming Pin configuration 1 Pin configuration
DRV 1 6 VS GND 2 5 TEST VSENSE 3 4 MFIO
Figure 2 Pin configuration Table 2 Pin configuration Pin no. Pin name Pin type Function
1 DRV Output Driver output to control base or gate of the external transistor 2 GND GND IC ground 3 VSENSE Input Measurement of Vsense voltage 4 MFIO Input Multifunctional IO for resistive (via external Rset), DC voltage and PWM voltage dimming 5 TEST Output For test purpose, it must not be directly connected to ground. It is recommended to leave TEST pin open or attach a resistor to ground > 1 MΩ. 6 VS Input Supply voltage Datasheet 4 Revision 1.1 2018-12-3 Document Outline Features Protection features Target applications Advantages with respect to discrete solutions Product validation Device information Description Table of contents 1 Pin configuration 2 Functional description 3 Thermal characteristics 4 Absolute maximum ratings 5 Operating conditions 6 Electrical characteristics 7 Package information 8 References Revision history Disclaimer
