Datasheet 2N3906, MMBT3906, PZT3906 (ON Semiconductor) - 2
ManufacturerON Semiconductor
DescriptionPNP General-Purpose Amplifier
Pages / Page11 / 2 — 2 N 3906 / MMBT3906 / PZT. Absolute Maximum Ratings. Symbol. Parameter. …
Revision2
File Format / SizePDF / 516 Kb
2 N 3906 / MMBT3906 / PZT. Absolute Maximum Ratings. Symbol. Parameter. Value. Unit. 3906 —. Note:. N P Gen. era. Thermal Characteristics
2 N 3906 / MMBT3906 / PZT Absolute Maximum Ratings Symbol Parameter Value Unit 3906 — Note: N P Gen era Thermal Characteristics
(1) Stresses exceeding the absolute maximum ratings may damage the device. The device may not function or be opera- ble above the recommended operating conditions and stressing the parts to these levels is not recommended. In addi- tion, extended exposure to stresses above the recommended operating conditions may affect device reliability. The absolute maximum ratings are stress ratings only. Values are at TA = 25°C unless otherwise noted.
VCEO Collector-Emitter Voltage -40 V VCBO Collector-Base Voltage -40 V VEBO Emitter-Base Voltage -5.0 V
3906 —
IC Collector Current - Continuous -200 mA TJ, TSTG Operating and Storage Junction Temperature Range -55 to +150 °C
Note: P
1. These ratings are based on a maximum junction temperature of 150°C.
N P Gen
These are steady-state limits. ON Semiconductor should be consulted on applications involving pulsed or low-duty cycle operations.
era Thermal Characteristics l-Purpose
Maximum Symbol Parameter Unit 2N3906
(3)
MMBT3906
(2)
PZT3906
(3)
Amplifier
Total Device Dissipation 625 350 1,000 mW PD Derate Above 25°C 5.0 2.8 8.0 mW/°C RθJC Thermal Resistance, Junction to Case 83.3 °C/W RθJA Thermal Resistance, Junction to Ambient 200 357 125 °C/W
Notes:
2. Device is mounted on FR-4 PCB 1.6 inch X 1.6 inch X 0.06 inch. 3. PCB size: FR-4, 76 mm x 114 mm x 1.57 mm (3.0 inch x 4.5 inch x 0.062 inch) with minimum land pattern size. www.onsemi.com 2
