DatasheetsDatasheet LM4130 (National Semiconductor)
Manufacturer | National Semiconductor |
Description | Precision Micropower Low Dropout Voltage Reference |
Pages / Page | 12 / 1 — LM4130. Precision. LM4130 Precision Micropower Low Dropout Voltage … |
File Format / Size | PDF / 271 Kb |
LM4130. Precision. LM4130 Precision Micropower Low Dropout Voltage Reference. General Description. Features. Micropower. Low. Dropout
LM4130
November 1999
Precision LM4130 Precision Micropower Low Dropout Voltage Reference General Description Features
The LM4130 family of precision voltage references performs n Small SOT23-5 package
Micropower
comparable to the best laser-trimmed bipolar references, but n High output voltage accuracy 0.05% in cost effective CMOS technology. Key to this break through n Low Temperature Coefficient 10 ppm/˚C is the use of EEPROM registers for correction of curvature, n Stable with capacitive loads to 100µF tempco, and accuracy on a CMOS bandgap architecture that n Low dropout voltage ≤275 mV @ 10 mA allows package level programming to overcome assembly n Supply Current ≤75 µA shift. The shifts in voltage accuracy and tempco during as- sembly of die into plastic packages limit the accuracy of ref- n Full accuracy −40˚C to 85˚C erences trimmed with laser techniques. n Extended operation to 125˚C
Low
Unlike other LDO references, the LM4130 requires no output n Excellent load and line regulation capacitor. Neither is a buffer amplifier required, even with n Output current 20 mA loads up to 20mA. These advantages and the SOT23 pack- n Output impedance < 1Ω aging are important for cost-critical and space-critical appli- n Voltage options: 2.048V, 2.500V, and 4.096V
Dropout
cations. Series references provide lower power consumption than
Applications Summary
shunt references, since they don’t have to idle the maximum n Portable, battery powered equipment possible load current under no load conditions. This advan- n Instrumentation and process control tage, the low quiescent current (75µA), and the low dropout n Automotive & Industrial voltage(275mV) make the LM4130 ideal for battery-powered
V oltage
solutions. n Test equipment n Data acquisition systems The LM4130 is available in five grades (A, B, C, D and E) for greater flexibility. The best grade devices (A) have an initial n Precision regulators accuracy of 0.05% with guaranteed temperature coefficient n Battery chargers of 10ppm/˚C or less, while the lowest grade parts (E) have n Base stations
Reference
an initial accuracy of 0.5% and a tempco of 30ppm/˚C. n Communications n Medical equipment n Servo systems
Connection Diagram and Pin Configuration
DS101046-2 DS101046-1 Refer to the Ordering Information Table in this Data Sheet for Specific Part Number *Optional, Recommended for improved transient response and input noise reduction.
SOT23-5 Surface Mount Package
(See Application Information) © 1999 National Semiconductor Corporation DS101046 www.national.com
