Datasheet VOT8026AB, VOT8026AD, VOT8026AG (Vishay) - 10
ManufacturerVishay
DescriptionOptocoupler, Phototriac Output, Zero Crossing, High dV/dt, Low Input Current
Pages / Page11 / 10 — VOT8026AB, VOT8026AD, VOT8026AG. SOLDER PROFILES. IR Reflow Soldering …
Revision1.1
File Format / SizePDF / 187 Kb
VOT8026AB, VOT8026AD, VOT8026AG. SOLDER PROFILES. IR Reflow Soldering (JEDEC® J-STD-020C compliant). PROFILE ITEM. CONDITIONS
VOT8026AB, VOT8026AD, VOT8026AG SOLDER PROFILES IR Reflow Soldering (JEDEC® J-STD-020C compliant) PROFILE ITEM CONDITIONS
SOLDER PROFILES
Axis Title 300 10000 260 °C + 0 °C / - 5 °C
wave temperature 250 One time soldering reflow is recommended within the condition of temperature and time profile shown below. Do First wave Second wave not solder more than three times. 200 1000 +200 °C/s ine ne ne 150 -5 °C/s
2nd l 1st li 2nd li Preheat 100 +2 °C/s 100 Temperature (°C) - Temperature minimum (TS min.) 150 °C Preheat zone 50 - Temperature maximum (TS max.) 200 °C - Time (min. to max.) (tS) 90 s ± 30 s 0 10 Soldering zone 0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 - Temperature (TL) 217 °C 23017 Time (min) - Time (tL) 60 s Fig. 20 Peak temperature (Tp) 260 °C Ramp-up rate 3 °C/s max.
Hand Soldering by Soldering Iron
Ramp-down rate 3 °C/s to 6 °C/s Allow single lead soldering in every single process. One time soldering is recommended. Axis Titl 20 se 10000 10000 Temperature: 380 °C + 0 °C / - 5 °C Ramp-up Tp (260 °C) Time: 3 s max. TL (217 °C) Ramp-down
HANDLING AND STORAGE CONDITIONS
T 1000 S max. (200 °C) 1000 ESD level: HBM class 2 ine ne ne 60 s Floor life: unlimited t 2nd l L (soldering) T 1st li 2nd li S min. Conditions: Tamb < 30 °C, RH < 85 % 100 (150 °C) Temperarure (°C) 100 Moisture sensitivity level 1, according to J-STD-020 25 10 0 20 40 60 80 Time (s) 60 s to 120 s 35 s to 70 s Time (s) t 23016 S (preheat) Fig. 19
Wave Soldering (JEDEC JESD22-A111 compliant)
One time soldering is recommended within the condition of temperature. Temperature: 260 °C + 0 °C / - 5 °C Time: 10 s Preheat temperature: 25 °C to 140 °C Preheat time: 30 s to 80 s Rev. 1.1, 29-Oct-2018
10
Document Number: 84925 For technical questions, contact: optocoupleranswers@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
